Cambio-GOLDMUND 28
  • Iniciador del hilo Iniciador del hilo Maenoba
Maenoba
Maenoba
Goldmund, acreditadisima marca suiza, con un sonido de lo mas refinado que se puede encontrar, lo mismo la estetica. Esta etapa de potencia Mimesis 28 entrega 200w por canal y pesa 45 kilos, un verdadero lujo.
Mueve cualquier tipo de caja con autoridad y una sutiliza espectacular.
Si conoces la marca, ya sabes que es un Ferreri musical, en caso contrario los datos aqui;
TECHNICAL DATA :
POWER
- Nominal power : 2 x 200 W RMS (2 - 8 Ohms).
2 x 100 W RMS (1 - 16 Ohms).
- Maximum instantaneous power : > 2 x 400 W RMS (8 Ohms).
- Maximum voltage swing : 62 V peak.
- Maximum current swing : 28 A peak.
These figures for both channels driven.
FREQUENCY RESPONSE
These figures are valid for the circuit alone, at any level between 0 and nominal
power.
- +/- 0.1 dB, 0 - 300 kHz, +/- 1 dB, 0 - 800 kHz.
- +/- 3 dB, 0 - 2 MHz.
INPUT SENSITIVITY
- Nominal level : 1.45 V RMS.
- Voltage Gain : 29
- Input impedance : 52 kOhms.
GROUP DELAY
- Propagation delay < 140 ns stable with frequency from DC to 200 kHz.
DISTORTION
Figures valid for all levels from 0 to 26 V / 8 Ohms :
- Dynamic : TID < 0.01 % (- 80 dB).
- Static : THD < 0.01 % (- 80 dB).
SPEED
- Slew rate : > 200 V/us
- Rise time : < 300 ns.
CROSSTALK
- Separation : > 110 dB between channels. Isolated ground.
NOISE
- Signal-to noise ratio : > 115 dB (0.01 Hz - 1 Mhz).
- Weighted ASA A : > 130 dB.
OPERATING TEMPERATURE
- Room temperature : -30 to +40 degrees Celsius
(-22 to +104 degrees Fahrenheit).
- Internal temperature : +45 to +65 degrees Celsius
(+113 to +149 degrees Fahrenheit).
POWER SUPPLY
- Nominal line voltage : 117, 234 V (switchable).
- Input voltage range : +/- 10 %.
- Maximum power consumption : 1200 W.
- Power used in standby : 100 W.
- 4 toroidal transformers, 4 separated power supply.
GROUNDING
- Separated ground for each channel.
- Floating chassis connected to mains earth.
- Switch for optionally connecting both.
SAFETY FEATURES
- AC voltage fuse : min 10 A slow-blow for 220 V / 16 A slow-blow for 110 V.
FRONT PANEL CONTROLS
- 2 POWER keys.
- Protection against accidental power off.
REAR PANEL CONNECTORS AND CONTROLS
- Power cord: universal socket 3 lugs.
- Main fuse (16A slow-blow 110V / 10 A slow-blow 220 V).
- Green-yellow AC earth binding post.
- Black signal ground binding post.
- Output speaker 2 X 5 ways post.
- Input connector RCA (right and left).
- Input connector XLR for balanced input (right and left).
SIZE AND WEIGHT
- 44 cm (17") W x 44 cm (17") D x 17 cm (7") H.
- Weight : 45 kg net.
He sido su único dueño y su estado es inmejorable.
El precio de venta es de 3.750 euros, portes por cuenta del comprador.
Para cambios seria otro valor y podría interesarme algún reloj, IWC, Panerai, Omega, ...
Para cualquier duda o contacto, por MP.
Saludos:ok::
    5,5 KB · Visitas: 80
    5,5 KB · Visitas: 79
    5,5 KB · Visitas: 81
Gracias por las preguntas y algunas ofertas, ... pero sigue igual para estudiar algún cambio por un reloj o simplemente venta.
Como saben los que conocen esta marca, con un previo, esta etapa de potencia hará volar cualquier conjunto de cajas estéreo, con una calidad y sonido excepcional.
Un salu2.:ok::
Sigue buscando nuevo dueño y se puede estudiar algún cambio por un reloj o simplemente venta.
Excelente etapa de contrastada calidad de sonido.
Salu2.
Lo rebajamos a 3.500 euros, el resto en las misma condiciones.
En el mismo estado, ya que no está en uso y embalado.
Salu2.
Sigue esperando un nuevo dueño que disfrute esta maravilla.
Algún cambio por reloj es posible.
Salu2.
Lo subimos, recordando que sigue buscando nuevo dueño y que se puede estudiar algún cambio por reloj o simplemente venta.
Excelente etapa de potencia, con una maravillosa calidad de sonido a un precio inferior al 50% de su valor. :ok::
Salu2.
Salu2.
Sigue buscando nuevo dueño y que se puede estudiar algún cambio por reloj.
A la escucha de alguna oferta interesante, que hasta la fecha no ha cuajado.
Salu2.
Cambio por reloj es posible o parte de pago.
A ver si esta vez hay suerte y los ofrecimientos son atractivos para todos. Se admiten ofertas.
Salu2.
Se admiten ofertas.
Salu2
Recibida alguna oferta que no ha fructificado, sigo abierto a un cambio por reloj, ... es cuestión de estudiarlo.:ok::
Un salu2.
Cambio por reloj es posible o parte de pago. Ofertas M.P.
Salu2.
Salu2.
