Protrek PRG-200 GB3
  • Iniciador del hilo Iniciador del hilo Superaton
Superaton
Superaton
Cambio mi Casio Protrek PRG-200GB 3DR.
El reloj está en perfectísimo estado. Impoluto de caja y cristal sin la menor marca, solamente destacar que la correa sintética está mínimamente desgastada en la zona de la hebilla. La correa elástica (de serie en este modelo para poner sobre la ropa en actividades de montaña está perfecta).
Se trata de un ProTek Triple Sensor (altímetro, barómetro y brújula) y por supuesto solar.
No me interesa venderlo, solo cambiarlo, y lo valoro en unos 200€. Para cambios estoy solamente interesado en Divers y G-Shock.
Un saludo al foro.
Case / bezel material: Sintetic Leather / Stainless steel
Leather/Cloth Bands
Accompanied attached band
100-meter water resistance
Mineral Glass
Electro-luminescent backlight
Full auto EL light, selectable illumination duration, afterglow
Solar powered
Low-temperature resistant (–10 °C/14 °F)
Digital compass
Measures and displays direction as one of 16 points Measuring range: 0° to 359° Measuring unit: 1° 20 seconds continuous measurement Graphic direction pointer Bidirectional calibration and northerly calibration function Magnetic declination correction Bearing memory
Altimeter
Measuring range: –700 to 10,000 m (–2,300 to 32,800 ft.) Measuring unit: 5 m (20 ft.) Manual memory measurements (up to 25 records, each including altitude, date, time)High Altitude / Low Altitude memory Total Ascent / Decent memory Others: Reference altitude setting, altitude tendency graph, altitude differential *Changeover between meters (m) and feet (ft)
Barometer
Display range: 260 to 1,100 hPa (7.65 to 32.45 inHg) Display unit: 1 hPa (0.05 inHg) Atmospheric pressure tendency graph Atmospheric pressure differential graphic *Changeover between hPa and inHg
Thermometer
Display range: –10 to 60 °C (14 to 140 °F) Display unit: 0.1 °C (0.2 °F) *Changeover between Celsius (°C) and Fahrenheit (°F)
Duplex LC display
World time
31 time zones (48 cities), city code display, daylight saving on/off
Sunrise, sunset time display Sunrise time and sunset time for specific date, daylight pointers
1/100-second stopwatch Measuring capacity: 23:59'59.99'' Measuring modes: Elapsed time, split time, 1st-2nd place times
Countdown timer Measuring unit: 1 second Countdown start time setting range: 24 hours Countdown start time setting range: 1 minute to 24 hours (1-minute increments and 1-hour increments)
Daily alarms 5 independent daily alarms
Hourly time signal
Battery level indicator
Power Saving (display goes blank to save power when the watch is left in the dark)
Full auto-calendar (to year 2099)
12/24-hour format
Button operation tone on/off
Regular timekeeping: Hour, minute, second, pm, year, month, date, day
Accuracy: ±15 seconds per month
Approx. battery operating time: 6 months on rechargeable battery (operation period with normal use without exposure to light after charge) 23 months on rechargeable battery (operation period when stored in total darkness with the power save function on after full charge)
Size of case/total weight: 56.2 X 50.2 X 11.3 mm/67 g EL:Blue Green
[TABLE="align: left"]
[TR]
[/TR]
[TR]
[TD]Marca:[/TD]
[TD]Casio[/TD]
[/TR]
[TR]
[TD]Modelo:[/TD]
[TD]Protrek-PRG200GB3[/TD]
[/TR]
[TR]
[TD]Año de compra:[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]Usado[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Movimiento:[/TD]
[TD]Cuarzo-Solar[/TD]
[/TR]
[TR]
[TD]Caja (medidas):[/TD]
[TD]56.2 X 50.2[/TD]
[/TR]
[TR]
[TD]Cristal:[/TD]
[TD]Mineral[/TD]
[/TR]
[TR]
[TD]Esfera:[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Brazalete:[/TD]
[TD]2: Uno sintético + uno elástico[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]¿Estuche? s/n[/TD]
[TD]SI[/TD]
[/TR]
[TR]
[TD]¿Documentación? s/n[/TD]
[TD]SI[/TD]
[/TR]
[TR]
[TD]NO[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Precio: (o Cambio)[/TD]
[TD]CAMBIO[/TD]
[/TR]
[TR]
[TD]¿Envío incluido? s/n[/TD]
[TD]SI[/TD]
[/TR]
[TR]
[TD]Forma de envío[/TD]
[TD]MRW 24h[/TD]
[/TR]
[/TABLE]
Algunas propuestas pero nada cerrado. Pasado el mes de rigor lo subo. Abierto principalmente a cambio por G-Shock o algún Diver...
Saludos a todos.
