jmg
De la casa
Saco a la venta esta edicion poco vista, y cada vez mas dificil de conseguir, y lo digo por experiencia
Estado, como nuevo, ya que tiene un mes escaso, ni rayas, ni microrayas, ni nada
Caracteristicas muchas, tiene un manual que parece el libro gordo de petete, copio y pego porque sino no acabaria.
Casio Protrek Tough Solar Triple Sensor Men's Watch PRG-110C-4D
Model: PRG-110C-4D PRG 110C 4D PRG110C-4D PRG 110C-4D
1/100-second stopwatch
Measuring capacity: 23:59'59.99"
Measuring modes: Elapsed time, split time, 1st-2nd place times
12/24-hour format
Accuracy: ±20 seconds per month
Altimeter
Measuring range: -700 to 10,000m (-2,300 to 32,800 ft.)
Measuring unit: 5m (20 ft.)
Auto memory measurements
(Up to 40 sets of data, each including altitude, month, date, time)
High Altitude Memory/Low Altitude Memory
Cumulative Ascent/Descent Memory
Total Ascent/Descent Memory
Altitude differential
Others: Reference altitude setting, altitude tendency graph
4 display formats, Altitude measurment type (0'005" or 2'00")
*Changeover between meters(m) and feet(ft.)
Approx. battery operating time
6 months on Rechargeable Battery (Operating period with normal use without exposure to light after charge)
20 months on Rechargeable Battery (Operating period when stored in total darkness with the Power Save function ON after full charge)
Full auto-calendar (to year 2099)
Barometer
Display range: 260 to 1,100 hPa (7.65 to 32.45 inHg)
Display unit: 1 hPa (0.05 inHg)
Atmospheric pressure tendency graph
Atmospheric pressure differential graphic
Changeover between hPa and inHg
Battery level indicator
Button operation tone on/off
Countdown timer
Measuring unit: 1 second
Countdown range: 24 hours
Countdown start time setting range: 1 minute to 24 hours (1-minute increments and 1-hour increments)
Daily alarms
5 independent daily alarms
Digital compass
Measures and displays direction as one of 16 points
Measuring range: 0° to 359°
Measuring unit: 1°
20 seconds continuous measurement
Graphic direction pointer
Bidirectional calibration and northerly calibration function
Magnetic declination correction
Bearing memory
Electro-luminescent backlight
Full auto EL light
Hourly time signal
Low temperature resistant (-10°C/14°F)
Power Save Function
(automatically disables LCD if the watch is left in the dark for approximately 60 to 70 minutes, and sensor measurements if the watch is left in the dark for six or seven days)
Regular timekeeping
Hour, minutes, seconds, pm, year, month, date, day
Solar powered
Thermometer
Display range: -10 to 60°C (14 to 140°F)
Display unit: 0.1°C(0.2°F)
Changeover between Celsius(°C) and Fahrenheit(°F)
World time
29 time zones (30 cities), city code display, daylight saving on/off
Size of case / total weight
PRG-110C ...... 56.9 X 47.4 X 11.5 mm / 62
El precio, puesto en casa por correo certificado es de 165 euros. Creo que un precio bueno teniendo en cuenta el stock que ahi (podeis comprobarlo en la web
Y ahora las fotos:
By clinisbuz at 2010-08-04
By clinisbuz at 2010-09-04
En este caso no cierro las puertas a algun cambio, pero ya os digo que raro sera que me tenteis
, ahora mismo estoy en fase de relax relojeristico.
Cualquier cosa un privado.
12/24-hour format
Altimeter
Barometer
Countdown timer
Daily alarms
Digital compass
Measuring unit: 1°
Bearing memory
Full auto EL light
Hourly time signal
Power Save Function
Regular timekeeping
Solar powered
Thermometer
World time
)Y ahora las fotos:
, ahora mismo estoy en fase de relax relojeristico. Cualquier cosa un privado.
