SINN UX (con armis) a mitad de precio.
  • Iniciador del hilo Iniciador del hilo anferro
anferro
anferro
Vendo Sinn Ux con armis.
COSC,
5000 metros !!!!!!!!!!
Cuarzo termocompensado.
3 años de garantía (hasta Junio de 2014).
Antimagnético.
Acero de submarino,
Tecnología HYDRO,
etc...
¡Una pasada!
Estas son sus características detalladas:
Temperature-stabilized chronometer quartz movement
ETA 955.652
7 bearing jewels
Seconds stop function
Shock resistant as per DIN 8308
Anti-magnetic as per DIN 8309
Case
Case made of German submarine steel, bead-blasted
Sapphire crystal glass in front, anti-reflective on both sides
Case back screw-fastened
Water-resistant as per DIN 8310
Pressure resistance of the movement up to 5,000 m diving depth (= 500 bar) and of the case up to 12,000 m diving depth (1,200 bar), certified by Germanischer Lloyd Hamburg
According to the technical demands for the diving norm DIN 8306
Tested based on European diving equipment standards EN 250 / EN14143 and certified by Germanischer Lloyd Hamburg
Low pressure resistant
Functions
Hours, minutes, seconds
Date display
Diver’s bezel with minute ratcheting and luminous key mark
SINN Technologies
HYDRO Technology for perfect readability even under water and freedom from reflection at any angle and completely free from fogging
Bezel with TEGIMENT Technology, therefore especially scratch-resistant
Captive bezel
Temperature resistance technology, therefore functionally reliable
at temperatures from -45 °C up to +60°C
Crown with D3-System
Dimensions and Weight
Case diameter: 44 mm
Band lug width: 22 mm
Case thickness: 13.3 mm
Weight without strap: 105 gramme
Dial and Hands
Matte black dial
Indices coated with luminescent colour
Hour, minute and second hand coated with luminescent color
Warranty 3 years
Está en perfecto estado.
Comprado el 21 de Junio de 2011.
Con caja, garantía, certificado COSC, manual, herramienta de cambio de correa, eslabones sobrantes.
El PVP es de 1495 euros.
Yo lo vendo por la mitad de precio, 750 euros, con gastos de envío incluidos.. Un 50% de descuento para un reloj con 4 meses que está como nuevo.
Envío asegurado y urgente, tras ingreso o transferencia.
Gracias. Saludos.
PD: Con la Isofrane que tengo en venta queda de lujo.
