Sí, la trasera en el 305 es de zafiro y en el 389 de titanio, en las especificaciones de la casa no pone más respecto al "amagnetic":
[TD="class: schtec, colspan: 2"]
PAM 305
Movement:
automatic mechanical, Panerai P.9000 calibre, executed entirely by Panerai, 13 ¾ lignes, 7.9 mm thick, 28 jewels, Glucydur® balance, 28,800 alternations/hour. Power reserve 3 days, two barrels. Incablock® anti-shock device. 195 components.
Functions:
hours, minutes, small seconds, date, calculation of immersion time.
Case:
diameter 47 mm, brushed titanium.
Bezel:
brushed titanium with polished edges, anti-clockwise unidirectional rotating bezel with graduated scale for calculating the time of immersion and ratchet click at minute intervals.
Back:
see-through sapphire crystal.
Device protecting the crown:
(protected as a Trademark) brushed titanium.
Crystal:
sapphire, made from corundum, 4 mm thick. Anti-reflective coating.
Water- resistance:
30 bar (~300 metres).
Strap:
PANERAI personalised rubber strap and large-size brushed titanium buckle. Supplied with a second interchangeable strap, a tool to change the strap and a steel screwdriver.
PAM 389
Movement:
Automatic mechanical, Panerai P.9000
calibre,
executed entirely by Panerai, 13¾ lignes, 7.9 mm thick, 28 jewels, Glucydur® balance, 28,800 alternations/hour. Incabloc® anti-shock device. Power reserve 3 days, two barrels. 197 components.
Functions:
Hours, minutes, small seconds, date, calculation of immersion time.
Case:
Diameter 47 mm,
brushed titanium.
Bezel:
Anti-clockwise unidirectional rotating bezel
in ceramic
and brushed titanium with polished edges, graduated scale for calculating the time of immersion and ratchet click at minute intervals.
Back:
Screw, titanium.
(protected as a trademark) Brushed
titanium
Dial:
Black with applied luminous hour markers.
Date at 3 o’clock, seconds at 9 o’clock.
Crystal
Sapphire, formed of corundum, 3.2 mm thick. Anti-reflective coating.
Water- resistance:
30 bar (
300 metres)
Strap:
titanium
buckle.
[/TD]
