¿Que Seiko vintage os quedariais de los que muestro?
  • Iniciador del hilo Iniciador del hilo Alexrovin
Alexrovin
Alexrovin
Navegando por la red he visto una pagina donde un afortunado caballero mostraba su colección de Vintages todos Seiko una pasada:
Todos los Seiko 5 vintage los tiene este señor
Sobran las palabras...a disfrutar amigos.
5126-6030, one of the first 5 sports series.
5126-6010, usually 5 sports has these inner rotating bezel, glass crystal and 70m water proof ratings.
5126-8100, i like the way lumi was "aged" on this one.
6126-6030, colorful dial...
So who said B&R had first square+round casing ;-)
5126-8130 again with other color combo.
Now the 6106 calibered 5 sports, 61xx caliber was also used as base movement for the automatic chronograpghs.
6106-6040.
6106-8569, some export only version doesn't have 5 sports scription on them.
6106-6399...very funky, and i like it.
6106-8100, it almost regular 5 or diver's, but 70m WP rating suggested it's a 5 sports variant.
Now the 6119 caliber, i think i have a lot on this kind, here's 6119-8460, almost carry over design from the model above.
6119-7083, the cylinder shaped indexes are filled with full of lumi material.
6119-7160.
Orange dialed 6119-6400.
Same 6119-6400 with brown dial, i'm looking for green one, if someone has it, email me ;-)
6119-7160 with cylinder index again, but yellow dialed version.
Square shaped case agin on this 6119-6053.
Same 6119-6053 ref. number, dial color variation.
Now this one has outer rotating bezel,6119-8121.
6119-8121 again with silver blue dial.
Checkered bezel, 6119-7123.
6119-7120, has different index.
Funky lime green dialed 6119-8400.
I think i like this blue one better,6119-8450.
Smaller cased, but has inner rotating bezel,6119-6023.
Same 6119-6023, dial variation again.
I couldn't read case number on this 6119 because someone engraved his inicials, but very unusual Arabic numeraled 6119.
Now the 6306 calibered kind, these were only sold outside of the domestic market.
6306-836A.
6306-836A with black chapter ring, i'm not sure second hand is original.
Now the 6309.
6309-836A, almost same as 6306 above, but has pepsi bezel.
6309-548A, again these were only find outside of Japan.
I only have one 6319 example, 6319-8070.
Side by side with 6119, different case diameter, and shape of the hands but same concept...
Now the 7xxx calibered kinds, this is the 7006-8030.
7009-8570.
7009-8570 with black dial, amature re-lumi job on this one.
7019-6030, looks like a 5126 older model...
Here's Arabic numeral dial again,7019-6040, pretty rare on the 5 sports i think.
7019-6020, i like this one a lot.
Back in 1997, Seiko re-issued some 5 sports with newer 7S36 movement which they are still using today.
Here's a 7S36-0110, the cylinder indexes are now filled with luminova (Seiko call them Lumibright).
I think this 6119 were used as a model.
7S36-0050.
Again similer model was chosen to be reproduced.
Voy a por la fregona que vaya charco e dejado....:drool:
Muy bueno, me gustan los Seiko y los vintage, por cierto este hilo hubiese correspondido mejor al foro vintage. Gracias por las fotos. Saludos
Ufff...que bonitos Seiko!!
Me ha gustado mucho lo 6309-836 de bisel pepsi, que pasada.
:cool1:
Tienes razón voy a comentarlo en el foro Vintage..
y tanto aun estoy babeando yo si fuera tu me quedaria con todos tienes una coleccion magnifica, felicidades
Lo he puesto en el general pero pega mas aquí, ahora esta en los dos sitios.
6106-6040.
6119-7160.
6306-836A.
Now the 6309.
7009-8570.
7S36-0050.
Voy a por la fregona que vaya charco e dejado....:drool:​
Macho, te has colao!!!
Pensaba que ibas a poner cuatro o cinco... Me quedo casi con la mitad.:pardon:
Eso digo yo...
Empiezo a bajar y digo, el primero mola, a ver el segundo, pues también.... y el tercero, y el cuarto..... joder, si hay más de veinte. :D
Todos bien chulos :ok::
El 8450 o el primero de todos. Pero admito que la elección es difícil. Son chulísimos casi todos,
Yo lo tengo claro, me quedo con el Seiko 5.
Uffff puesto así es como entrar en una tienda de golosinas no te puedes conformar sólo con ujq. Dejó paso a los beteranos
Primeeens!!!!. Yo me quedaría con los 6119-6053.
Pues a mi me gustan casi todos pero quizas este:
Seiko 7006
Si pudiera, me quedaba con todos... pero especialmente con el 6106-8569.
Os habeis fijado en los detalles unas rayitas que seran los segunderos en el dial, porque a dia de hoy Seiko no las pondra me encantan le dan un toque de mas currado nose mirad me refiero a estas rayitas:
No se ven muchos a la venta en el foro por eso.
Amigo, He unificado los 2 hilos en uno solo, entre otras cosas porque además de que se produce una dispersión de las respuestas, esta claramente especificado en las normas que no se puede repetir mismos hilos en distintos sub-foros, (si se puede poner un enlace a otro hilo, pero no poner el mismo hilo). Un saludo
Difícil elección imposible decidir un saludo
Ufff ni idea, yoo creo que todos...:hmm:
Ok, de acuerdo si es mejor así otro dia me fijaré mas eres muy amable, gracias!!
Sin lugar a dudas...todos! Uno más lindo que otro. Saludos
Fernando
difícil difícil, son una maravilla todos.
Bnoches
Yo cogería el 6119-6053. Es precioso.
Hola Alexrovin....si llegas a tener esta colección y no los presentas antes....no se que hubiera hecho. Aunque prácticamente ya he cerrado la mia, no le haría ascos para completarla con algun naranjita:). Un saludo
ja,ja Antonio que mas quisera poseer uno almenos de ellos, voy detras de un par de Orient's e colgado algun hilo pero son estos:
Saludos!!
