Reloj seiko arctura kinetic cronograf
  • Iniciador del hilo Iniciador del hilo chemapamundi19
C
chemapamundi19
[TABLE="class: MsoNormalTable"]
[TR]
[TD][/TD]
[TD] [h=2][FONT=&quot]RELOJ SEIKO ARCTURA KINETIC CRONOGRAF[/FONT][/h] [/TD]
[/TR]
[/TABLE]
[FONT=&quot]HOLA A TODOS, SIGUIENDO CON LA RESTRUCTURACION DE LA PLANTILLA, COMO HA ENTRADO VARIOS PUES VARIOS TIENEN QUE SALIR Y AHORA LE HA TOCADO A UNO QUE NUNCA PENSE QUE VENDERIA, SE TRATA DE ESTE SEIKO ARCTURA KINETIC CRONOGRAF DIAL BLANCO PRECIOSO. EL RELOJ ESTA BASTANTE BIEN (COMO SE PUEDE APRECIAR EN LAS FOTOGRAFIAS ADJUNTAS) LO UNICO QUE SE LE PUEDE APRECIAR SON UNOS MICROPELILLOS EN LA CAJA A LA ALTURA ENTRE EL 7 Y EL OCHO QUE HE INTENTADO QUE SE VEAN EN LAS FOTOGRAFIAS ADJUNTAS, NO SON NADA PERO ME GUSTA DECIRLO TODO. HACE SEIS MESES LE HICE UNA REVISION EN MI RELOJERO Y LE CAMBIEN EL ACUMULADOR KINETIC POR LO QUE EL FUNCIONAMIENTO ES PERFECTO COMO RECIEN COMPRADO. EL RELOJ LO ENTREGO CON CORREA DE CAUCHO CORTADA PARA MUÑECAS DE 18, 18,50 CTMS, PERO ADEMAS TAMBIEN ENTREGO ARMIS ORIGINAL DE SEIKO Y EXPECIFICO PARA ESTE RELOJ CON ESLABONES SOBRANTES.[/FONT]
[FONT=&quot]CARACTERISTICAS DEL RELOJ:[/FONT] [FONT=&quot]Type: Kinetic Chronograph
Movement: Precise Kinetic movement
Calibre: 7L22
Crystal: Sapphire crystal
Dial: White dial
[/FONT]
[FONT=&quot]Lumibrite hands
Case: Stainless steel
Case diameter: 44mm
Case thickness: 13mm
Water resistance: 100 meters
Bracelet/Strap: Intergrated matching steel bracelet
Movement from Japan
[/FONT][FONT=&quot][/FONT]
[FONT=&quot]EL RELOJ ENTREGO CAJA ORIGINAL, MANUALES, TARJETA GARANTIA CADUCADA, ASI COMO EL ARMIS ORIGINAL COMPLETO.[/FONT] [FONT=&quot]EL PRECIO QUE LE PONGO ES DE 240 EUROS CON ENVIO INCLUIDO POR CORREO CERTICADO CON Nº SEGUIMIENTO.[/FONT]
[FONT=&quot]AHORA UNAS FOTITOS DEL ARTISTA:
[/FONT] dsc02688sm.webp[FONT=&quot]
[/FONT]dsc02687e.webp[FONT=&quot]
[/FONT]dsc02685sw.webp[FONT=&quot]
[/FONT]dsc02684x.webp[FONT=&quot]
[/FONT]dsc02686z.webp[FONT=&quot]
GRACIAS A TODOS POR LLEGAR HASTA AQUI Y AL FORO POR CEDERNOS ESTE ESPACIO.
UN SALUDO.
CHEMA.
[/FONT]
Pido por fabor a los moderadores si pueden añadir la siguiente foto:
Gracias.
Hola compañeros una subidita con rebaja importante ya que necesito cash para otra pieza.
Ahora puede ser tuyo por 180 euros con envio incluido.
Un saludo a todos/as.
Reloj VENDIDO.
Gracias a todos los interesados y en especial al estupendo forero que se lo queda y al foro por el espacio que nos cede.
Un saludos a todos/as.​
