Para buzz aldrin un omega no es suficiente
  • Iniciador del hilo Iniciador del hilo Harkaitz
Harkaitz
Harkaitz
A mi me daban 2
Jajaja, nunca había visto una armis hecho de otro reloj, a excepción de Breitling (utc)
¿sabes cuáles son?
Sistema redundante, por si uno se estropea... :whist::
Será para saber la hora en la Tierra y en la Luna. Es curioso el apaño.
Genio y figura....
Y pulseras se ve que tampoco...
Que cansina la arm party.
¿sabes cuáles son?
segun dicen en reddit (donde vi la foto), uno es un speedmaster professional x-33 y un deville coaxial chronoscope GMT.
solucion hecha por el propio buzz.
La explicacion en ingles de por que usa 2 relojes. Yo no me entero muy bien de lo que quiere decir:
Why do you wear two watch faces on one band?
So if one stops, I got the other one! No, there's a practical reason. You see I'm very proud that in 1970 I suggested to a watch company that normally on a watch when you pull out the stem the second handstops and you have to move the minute hand around once to get the hour hand to move. I said to the watch company: "You don't want to stop the second hand, and you don't want to forget where the minute hand is. Otherwise you'll lose the accuracy." I said they should have two hour hands, one of which stays tied to the minute hand and the other which moves just one hour at a time.
If you screw that up, you can look down here at the second face.
That's why you have two hour hands - one of them is home time, and the other local time. I didn't get paid anything for that invention! I showed it to them and they said "Oh, isn't that something!" But this two on one strap is one-of-a-kind. They're both Omega, one is the watch they use on the Space Station.
Se refiere a que para cambiar la hora, con respecto a una inicial o local, al parar el segundero y mover la de la hora, se pierde exactitud.
Lo que no sé es porqué no lleva un GMT...
Es curiosa la imagen,yo tampoco había visto algo igual,desde luego no pasa desapercibido.
Según dice, para no olvidar dónde estaba el minutero al cambiar la hora.
Cuando va de elegante, uno a cada lado, no hay que hacer experimentos raros cuando vas de traje!
Aquí se ven un poco mejor
Pedazo muñeca que tiene el tío este no?
Grande Buzz. Tang sucks!!
Y además es muy activo en facebook! no para de hacer cosas y las atualiza (o se las actualizan) en su perfil. Uno de los grandes el Buzz!
A mi tanta chatarra me resulta pesada, no tengo nada en contra pero creo que exige un esfuerzo extra, no por el peso sino por el quita y pon. Sólo llevo el reloj. Ni anillo, ni cadena, nada que no sea el peluco.
Bonjour.
Bonjour.
Es lastre, se lo pone para no volver a la luna sin querer
También se rumorea que le gusta llevar peso en la muñeca para ser más efectivo contra los que le dicen que nunca ha estado en la luna
Gif con explicación gráfica de la 3era ley de Newton, toda acción acarrea una reacción. Si le tocas la moral a buzz, te da la hora con uno de sus omegas.
Desde luego original lo es y mucho,,se acabo el girar la muñeca para ver la hora.
Que crack, nunca había visto nada igual. Mola la chupa militar y las pulseras, all American way of life....
