S
seakermdc
Están haciendo prereservas en el distribuidor europeo Forasec. 700 eurillos de nada, un poco caro. Se envía a finales de Junio, y parece que los nuevos modelos pasan a incorporar calibre Sellita SW200-1 en vez del STP que traían los anteriores modelos.
First edition 500 pieces, future editions may be released depening on demand. CuSn8 solid bronze case and bronze crown. 42mm without crown Fine brushed finish 22mm at lugs. Tapers to 20mm at buckle. 51mm tbc Sellita SW200-1 Swiss Made automatic movement. 26 Jewels, 28.000 bph, power reserve of 38 hours and hacking function. Also used by brands like Sinn, Oris, Baume & Mercier, Bell & Ross, Eterna and many more. 500m - 50 ATM, viton gasket used in screwed-in case back Sapphire, high-domed with AR coating on the inside. Dark Blue sandwich dial. The seconds hand has a traffic light design. No Markers on the dial and bezel feature BWG9 Super LumiNova (white with blue radiation). The hands and pip on the bezel have C3 Super LumiNova (green) to give more contrast in the dark. The bezel is uni-directional with a blue matte ceramic insert with SuperLuminova BWG9 (markers) and C3 (pip at 12) lume. Itr can be used to set a second time zone. Blue rubber strap in "tropical" style and a vintage look brown leather strap. CuSn8 Bronze buckle with logo. Magrette travel case 24 months
[TD="class: spec-title"] Limitation: [/TD]
[TD="class: spec-title"] Case: [/TD]
[TD="class: spec-title"] Size: [/TD]
[TD="class: spec-title"] Finish: [/TD]
[TD="class: spec-title"] Strap width: [/TD]
[TD="class: spec-title"] Lug-to-lug: [/TD]
[TD="class: spec-title"] Height: [/TD]
[TD="class: spec-title"] Movement: [/TD]
[TD="class: spec-title"] WR: [/TD]
[TD="class: spec-title"] Crystal: [/TD]
[TD="class: spec-title"] Dial: [/TD]
[TD="class: spec-title"] Date window: [/TD]
[TD="class: spec-title"] Lume: [/TD]
[TD="class: spec-title"] Bezel: [/TD]
[TD="class: spec-title"] Strap(s): [/TD]
[TD="class: spec-title"] Buckle: [/TD]
[TD="class: spec-title"] Packaging: [/TD]
[TD="class: spec-title"] Warranty: [/TD]
