Los sueños también tienen medidas:
  • Iniciador del hilo Iniciador del hilo PET
P
PET
Este es mi próximo y único sueño. No pienso fijarme en nada más hasta conseguirlo. Desde hoy soy relojilmente casto, y así permaneceré años varios.
Aún siendo un sueño, tiene sus medidas y su precio. Estos son sus datos:
Annual calendar Ref. 5396 R
Movement:
- Caliber 324 S QA LU 24H
- Self-winding mechanical movement, three-aperture Annual Calendar, with moon phases and am/pm indicator
Diameter: 33.30mm
Height: 5.78
Number of parts: 347
Number of jewels: 34
Power reserve: Min. 35 hours, max. 45 hours
Winding rotor: 21K gold central rotor, unidirectional winding
Balance spring: Flat
Frequency: 28,800 semi-oscillations per hour (4 Hz)
Stud: Movable
Functions: Two-position crown:
- Pulled out: to set the time
- Pushed in: to wind the watch
Displays: Hours, minutes, seconds
Subsidiary dial:
- 24 hours at 6 o'clock
Apertures:
- Day of week and month at 12 o’clock
- Date at 6 o'clock
- Moon phase at 6 o'clock
Corrector buttons:
- At 10 o'clock: day-of-week correction
- At 2 o'clock: month correction
- At 4 o'clock: date correction
- At 8 o'clock: moon-phase correction
- Included: correction stylus in ebony and 18K rose gold
Hallmark: Geneva Seal
Features
Case:
- 18K rose gold
- Sapphire-crystal snap back and water-resistant crown
- Water-resistant to 25 meters
Case dimensions:
- Diameter: 38 mm
- Thickness: 11 mm
- Width between lugs: 21 mm
Dial:
- Two-tone silvery color, navy blue transfer-printed scales
- Leaf-shaped hour, minute and 24-hour hands in blued steel
- Counterbalanced seconds hand in blued steel
Strap: Alligator with large rectangular scales, matte dark brown, hand-stitched with fold-over clasp in 18K rose gold
Y como todos los relojes tienen un precio, este tambien: vale 24000 euritos.
Un sueño precioso... espero que lo consigas :)
Pero recuerda... "You never actually own a Patek Philippe. You merely look after it for the next generation". ;-)
Barato no es, pero es una maravilla, precioso.... por ponerle un pero...... bueno, no te lo digo ;-) pero yo me quedaría con el Nautilus.
Desilusión: leyendo "sueños" y "medidas", ya esperaba yo ver alguna maciza...
Por cierto: bonito relós ;-)
Parecías bobo tú eligiendo relojes...
Un sueño precioso...para nunca despertar...
bonito sueño, espero que lo consigas
un saludo :)
Lo único que no me gusta es el tamaño, un poco pequeño para mi gusto, aunque sé que los relojes de vestir son así y también veo demasiadas rayas en el dial.
Buena suerte y paciencia, que la castidad no ha de ser fácil, y se te cruzarán muchas tentaciones por el camino. Pero bueno, aunque "peques" con algún Seiko de vez en cuando, tampoco te alejarás tanto del camino :D . Saludos
Ese reloj No es caro, vale lo que vale, me atrevo a decir que es uno de los relojes con un precio mas "justo" que he visto en mucho tiempo.
No muevas el timón de tu barco PET, esa maravilla merece la pena una buena temporada de abstinencia...relojerial ;-).
Un abrazo y comparto al 100x100 tu ilusión por esa maravilla :) :)
Me juego lo q vale ese reloj a q no aguntas, :D:D
...suerte....🙂
A mi tambíen me ha parecido mucho eso de "años varios" pero en fin..... espero que lo consigas, el reloj es precioso.
En mi caso las medidas de los sueños son 90-60-90. No sé si coinciden con las tuyas.
PD: Bonito sueño, ojala te se realice je je
Es un sueño que se te va a hacer realidad y encima nos vas a dar envidia ( de la sana, por supuesto) :D
Es lo maximo a lo que se puede aspirar;tener un patek.Suerte.
Persevera, persevera... pero las tentaciones son muchas...
"Los sueños también tienen medidas": 90-50-90 (bueno lo digo por el tópico) a mi me gustan mas delgaditas).
Y También un precio, se podría añadir. Merece la pena esperar para tener un reloj así.
`He tenido ese modelo en mis manos, hace unos diez dias. Decirte que es mas grande de lo que sus 38 mm especifican , lo cual me agrado bastante. junto a mi 3573 no desentonaba encuanto a tamaño. La calidad que emana es de otra division. Y bonito hasta decir basta. Yo tambien me apunto a este contigo, sino te importa claro.
¡¡ Joder !! no sabia yo que entraban tantos Euros en 33 mm. de diametro ;-)
A propósito, acaban de reabrir la sede de la Rué du Rhone en Ginebra, decoración art decó en algunos pisos, los especialistas de versalles para la reecolocación de las lámparas....un perfume especial hecho por los especialistas de Givaudan para cada habitación, y el hallazgo en un arcón de 100 calibres 9.90 fabricados en 1956, cuando en 1996 decidieron "mudar" parte del negocio a Plan-Les-Ouates. Diez años mas tarde decidieron reeditar 100 ejemplares con denominación 5105 en platino, y además 300 del 5565 en acero (comentado hace dias con acogida desigual, en homenaje a los relojes PP con estricto contenido funcional y ausencia de metales nobles, para la reapertura de la sede). En fin, que si te lo compras, te acompañamos a comprarlo a Ginebra y te pagamos una cena.....yo preferiría hacer el viaje que comprarlo aquí, un cosa así merece ir a la cuna de la marca, les ha quedado de cine, en fin PP es PP y una visita a su sede siempre merece la pena.
24000 € pero existen esos juntos' jejjeej
Cuando realices tu sueño que no vas a tardar mucho ya lo verás, te seguirán gustando los relojes, todos los relojes,pero de una manera completamente diferente.
Te dirá muchas veces tu subconciente, ahora si que tienes un reloj.
Enhorabuena por ese pedazo de sueño y por esa decisión.
Tienes uno mas asequible y muy parecido ,esteticamente claro.Es el 5296 tambien en oro rosa y con el mismo dial pero sin fases de la luna ni calendario anual.No es lo mismo pero esteticamente se parecen mucho y claro...ya no son 24000 sino 13000.Si no llegas a este yo me compraba fijo este:
