"Juego" de las agujas
  • Iniciador del hilo Iniciador del hilo Cyclops
C
Cyclops
Navegando por internet he encontrado este documento sobre Rolex:
https://www.rolexforums.com/showthread.php?t=8478
Y leyendo el punto sobre la puesta en hora veo referido algo sobre "play"(jugar" de las agujas pero no acabo de entender a que se refiere ni como se corrige, ¿me lo podrían explicar?
El fragmento es este:
Watch Winding Setting Etc.
Let's take the example that you want to set you watch at PRECISELY 11 o'clock AM on the 27th. of May 2007.
Take the following steps: (important things are underlined and in red):
1) Unscrew the winding crown counterclockwise. Two or three turns, and then the winding crown should "pop out" in the "winding position". If not, make SURE that the winding crown is free of the threads before winding the watch. Reason: if you turn the winding crown clockwise while it is still on the threads and if you are NOT pushing the winding crown inward whilst turning it, you might damage the threads. So again: Make sure that the winding crown is free of the threads before winding the watch!
2) Now you give your watch at LEAST 30-40 FULL windings by the crown. Wind the watch by turning the crown CLOCKWISE and NOT "back and forth" as some do! The reason to wind the watch manually when it has stopped: That way you make sure that the watch is FULLY wound and will have its full power reserve. By just "shaking it to get it going" you will NOT get the full power reserve. Do not be afraid of "over-winding" the watch (there is a safety catch to prevent over winding), but about 30 full windings should be enough.
3) IMPORTANT STEP! Remember that our example states that you want to get your watch going at 11 AM (in the "morning")??
What you do BEFORE MOVING THE HANDS is to pull out the winding crown FULLY (time setting position) and then you turn the hands to make SURE that both the hour hand and minute hand stand at FIVE OR SIX o'clock!
Reason: the date change mechanism (date-wheel) could be harmed if you change the date MANUALLY during the period from 21 to 01 o'clock. So by setting the hour and minute hand well off that period is strongly advised.
4) (now back to the date): Push the winding crown back to the SECOND notch (date change notch) and then advance the date MANUALLY via the winding crown until you reach the date of YESTERDAY (in our example: the 26th. of May).
5) Then you - once again - pull out the winding crown to the LAST notch (time setting position) and stop the seconds hand (that is now running since you have wound the watch manually!) at EXACTLY 12 o'clock (easier now to synchronise with another watch!).
6) Then you advance the hands by turning the winding crown clockwise. Keep a close eye on the date window as you advance the hands!. IF the date changes at midnight to the date of our example then you will have to advance the hands another 11 hours so that the date will change correctly at next midnight. If the date does NOT change, you have to advance the hands accordingly.
7) If you want to make the minute hand points EXACTLY on the given minute when the seconds hand has reached "12" (or "60" seconds), then you must know that there is some "play" in the hands.
So if you just set the minute hand according to our example (EXACTLY 11 AM so that the minute hand will point exactly on the 12) then you will notice that by "one minute past 11 AM" the minute hand will NOT (or probably not!) point EXACTLY and spot on on the minute but rather somewhat (like 15 seconds) PAST it due to the "play" in the hands!
Solution: Following the example, turn the minute hand approximately TEN minutes PAST "11 AM" and then turn the minute hand BACK again to the EXACT time (hour hand point at "11" and minute and seconds hand pointing - exactly - on "12"). Then - EVER SO GENTLY - turn the winding crown clockwise so that the minute hand actually points a bit (like "15 seconds" PAST the full minute marker). That way you adjusted to the "play" of the minute hand, and the minute hand will point EXACTLY on the minute next time the seconds hand reaches "twelve".
8) When you have wound the watch, set the time and date, screw the winding crown back so that the watch is once again waterproof. By the way: You do not have to screw it very hard onto the case. As soon as you feel some resistance, stop using more force on the crown."
Saludos!!
Nadie sabría aclararme esta duda?
Hace mención a evitar manipular en las 11;00 el 27 las manecillas cuando giras/tiras/desenroscas la corona...pero tampoco entiendo bien. Dice que lo que se debe hacer esta en rojo pero al copiar y pegar el texto se a perdido esta diferenciación de color.
Saludos!!
En realidad a lo que más me refiero es a este fragmento subrayado:
Hay dice que tienes que advertir que las agujas tienen un pequeño juego (holgura) cuando pretendas que la aguja de los minutos marque en las doce cuando la agua de segundos recorra la esfera. Dice ademas que si aprecias se ve como hay un minimo desfase que da la impresión aun a pesar de ser las 11 de la mañana que hace que la aguja de minutos parezca estar cuando pasa un minuto como 15" adelantado debido al "juego/holgura" en ese punto.
Para solucionar esto dice que se debe adelantar en ese punto la aguja de minutos 10 minutos y poner la misma otra vez marcha atrás en forma de conseguir que la aguja de la hora este exactamente a las 11 cuando la de segundos este en los 60' concretamente y entonces dar cuerda al reloj... Eso es a groso modo lo que he podido leer.
La verdad que he tenido varios Rolex y jamas he apreciado esto.
Play=holgura 🙂
SI justo pones la minutera a las 12h, y vienes de atrás (normal), debido a la holgura, cuando cierres la corona, y haga un minuto más, la minutera no estará sobre las 12 a la vez que el segundero.
SI te pasas de las 12, y después retrocedes la aguja minutera, entonces la dejas sobre el minuto exacto, es más probable que al cerrar la corona, el minutero, el segundero, y la horaria coincidan a las 12h, a las 12h 🙂)))
No se si me he explicado peor que el ingles 🙂))))
Si, es holgura en ese contexto. No esta dando pistas para jugar a modo Nintendo :laughing1:
El mecanismo arrastra las agujas. Si vienes de atrás , debido a la holgura, "tardará en arrastrar". Una vez ajustado, nunca alrededor de las 24H 🙂, es mejor pasarse de minutos, luego volver hacia atrás para colocar la minutera donde debe estar. Entonces metes la corrona para liberar el mecanismo.
No se como explicarlo mejor 😀DD
Ahhhhh, ya lo entiendo para que quede exacto vas un poco para alante y luegos ajustas hacia atrás, ya lo entiendo Muchas gracias a todos por vuestra ayuda:ok:::ok:: ya que en esto de la relojería estoy pez :-P
