Este si que lo tiene todo
  • Iniciador del hilo Iniciador del hilo Niven
Niven
Niven
Antiguos Moderadores
Acabo de ver esta "pequeña" maravilla:
Y no le falta de nada:
  • This is Japan Domestic Market Casio PROTREK Triple Sensor Wave Ceptor PRW-1100YTJ-1JF
  • Electro-luminescent backlight, Full auto EL light, afterglow
  • Solar Powered (solar charge system)
  • WR 10 Bar Waterproof
  • Titanium
  • Sapphire Glass with nonreflective coating
  • Low-temperature resistant (-10 °C/14 °F)
  • Wave Ceptor:automatic reception (5 times/(day)/manual operation ,
    <JAPAN>Receiving Wave:JJY, Frequency:40kHz/60kHz (Fukushima/Kyushu Dual band)
    <USA>Receiveing Wave:WWVB, Frequency: 60 kHz
    <Great Britain>Receiveing Wave:MSF, Frequency: 60 kHz
    <Germany>Receiving Wave:DCF77, Frequency: 77.5 kHz
  • Digital compass
    Measures and displays direction as one of 16 points
    Measuring range: 0 ° to 359 °
    Measuring unit: 1 °
    20 seconds continuous measurement
    Graphic direction pointer
    Bidirectional calibration and northerly calibration function
  • World Time
    29 time zones (30 cities), city code display, daylight saving on/off
    One-Touch City Code
  • Altimeter
    Measuring range: -700 to 10,000 m (-2,300 to 32,800 ft.)
    Measuring unit: 5 m (20 ft.)
    Auto memory measurements
    (up to 40 records, each including altitude, month, date, time)
    High Altitude / Low Altitude Memory
    Cumulative Ascent / Descent Memory
    Relative Altitude Display
    Altitude Tendency Graph
    Altitude Differential Graphic
    Altitude alarm
    *Changeover between meters (m) and feet (ft)
  • Barometer
    Display range: 260 to 1,100 hPa (7.65 to 32.45 inHg)
    Display unit: 1 hPa (0.05 inHg)
    Atmospheric pressure tendency graph
    Atmospheric pressure differential graphic
    *Changeover between hPa and inHg
  • Thermometer
    Display range: -10 to 60 °C (14 to 140 °F)
    Display unit: 0.1 °C (0.2 °F)
    *Changeover between Celsius ( °C) and Fahrenheit ( °F)
  • Duplex LC display
  • 1/100-second stopwatch
    Measuring capacity: 9:59'59.99''
    Measuring modes: Elapsed time, split time, 1st-2nd place times
  • Countdown timer
    Measuring unit: 1 second
    Countdown range: 60 minutes
    Countdown start time setting range: 1 to 60 minutes (1-minute increments)
    Others: Auto-repeat, progress beeper
  • Stop Watch Function : 1/100 second, 60 minutes
  • Daily alarms
    5 independent daily alarms
  • Hourly time signal
  • Battery power indicator
  • Power save function (automatically disables LCD if the watch is left in the dark for approximately 60 to 70 minutes, and sensor measurements if the watch is left in the dark for six or seven days)
  • Auto-calendar (to year 2099)
  • 12/24-hour format
  • Regular timekeeping: Hour, minutes, seconds, pm, month, date, day
  • Approx. battery operating time:
    6 months on Rechargeable Battery (Operation period with normal use without exposure to light after charge)
    21.5 months on Rechargeable Battery (Operation period when stored in total darkness with the Power Save function ON after full charge)
  • Size of Case(H×W×D) / total weight : 62.3×52.2×14.2/118g
  • Band Adust : C ring type
  • Accuracy : Quartz Movement / ±15 seconds per month
  • Comes with original CASIO box and Japanese manual
  • MSRP in Japan : 68,250 Yen (apprx. $ 595 USD)
enlace roto o perdido
Ahora solo queda encontrarlo barato ;-)
Yo tengo esa pequeña maravilla pero en titanio gris
Ah¡ de pequeña no tiene nada.
Ya lo se, por eso las comillas:D
Cuando me lo compre, que me lo compraré, será el cuarto que pasa por mis manos. ;-) :D
Es muy grande, pero es verdad que tiene todo! Tuve el "normal" y esta muy bien, y éste encima radio-contolado y zafiro... Si fuese un "pelín" mas pequeño...
Creo que zafiro no tiene.
"Sapphire Glass with nonreflective coating"
pues el mio es cristal mineral
8o No tira expressos! Uuuuf, que lista de specs! ;-) :cool1:
Y el mio también, se ve que con este quieren subir el nivel.
La verdad es que a mi me sobra con el mineral para este tipo de relojes.
Creo que te confundes con el PRG80, el PRW-1100 es un clon del 80, pero tiene radio control y zafiro.
Si, pero sigue siendo un prg 80.
Clavaito al PRG 80T
Si no hubieras puesto que es el PRW-1100YTJ-1JF hubiera pensado que es mi PRG 80 con armis de titanio. UNA GOZADA ( y tambien tengo el 60 pero.. este es el que me gusta)
¿Hay un PRG80 con horas mundiales y radiocontrolado?:huh:
Dime cual, que es mucho más barato y paso del zafiro.:)
Este modelo PRW-1100YTJ-1JF lo vende Higuchi por 52000 yenes, unos 350 €, lo podeis ver
Eso digo yo, es un prg 80 con zafiro y radiocontrolado llamado prw-1100
Radio controlado no pero con horas mundiales si.
igual, quitando el radiocontrolado y el zafiro.
Pues es una pena, porque con este se pasan de largo en la pasta.:(
100 euretes más barato que el que había visto en Ebay.
Aún demasiado caro, para el reloj que es, pero se me esta afilando demasiado el hocico....;-)
¿Que modelo es?
¿Que modelo es?.
Manolo
Prw-1100ytj-1jf
Pues teniendo en cuenta que, según ellos mismos, no capta la señal de radio en la mitad sur de España, me quedo con mi PRG-80YT que es "clavaito" (salvo por el zafiro)
No hdj80, si la capta, yo tengo un oceanus wave ceptor (radio controlado) y se me pone en hora a partir de las 12 a.m., y vivo en Melilla.
Para NIVEN Casio PRW-1100
Una pregunta para el que tenga este reloj concretamente el Casio PRW-1100 el modelo japones claro, y es que quisiera saber si esta todo echo de titanio, la caja y el armis, o lleva algunas piezas soportes del brazalete en resina o plastico???Gracias
