Rangeman GW 9400 J Master of G (made In Japan)
  • Iniciador del hilo Iniciador del hilo jmpresidente
jmpresidente
jmpresidente
Hola Compañeros
Saco a la venta mi MASTER OF G modelo Rangeman 9400 J (made in Japan) con la correa en fibra de carbono en vez de resina. modulo 3410P*JA
Lleva caja y papeles y esta usado con un uso moderado (ver fotos), por ello le pongo un precio de 200 euros mas 15 euros de envio certificado a peninsula.
Specifications;
  • Multiband 6
  • Digital compass (Measure the 16 orientation and angle(0° to 359°) , Bearing memory)
  • Barometer (Measuring range : 260 to 1,100 hPa)
  • Altimeter (Measuring range : -700 to 10,000 m)
  • Thermometer (Measuring range : -10 to 60 °C)
  • Stop watch (1/100 second measurement , 1000 hours meter , Split)
  • Countdown timer (Setting range: 1 minute to 24 hours , Measuring unit: 1 second)
  • 5 multi-alarm (Snooze function)
  • Hourly time signal
  • Battery indicator
  • Power saving function
  • Fully auto-calendar
  • 12/24 Hour display switching
  • Button Operation Tone on/off
  • LED-backlight (Full auto light , Super Illuminator , Afterglow function , Afterglow time switch function:1.5 second or 3 seconds)
  • After fully charged
  • Normal mode Approx 8 months
  • Power Saving Mode Approx 23 months
  • ±15 seconds per month
  • World Time 48 cities (31 times zones) + UTC
  • Daylight Saving Time function
  • Auto reception (Max 6 times/day)
  • Shock Resist
  • 20 BAR waterproof
  • Inorganic glass
  • Carbon Kevlar inserts Band
  • Tough Solar (Solar charge system)
  • 93 g
Subida con rebaja
185+15 de envío certificado a Península
vendido!
