Doble barrilete
  • Iniciador del hilo Iniciador del hilo yagocg07
yagocg07
yagocg07
Un reloj equipado con doble barrilete con cada vuelta de corona recarga a los por igual? Se descargan los dos por igual? No lo creo.
Siendo iguales los muelles reales pero no idénticos la carga será similar en todo momento pero no el par exactamente suministrado por ambos. Cómo se regula este desajuste mecánico?
Gracias. Un saludo.
No sé si en todos los casos será igual.
He encontrado esta explicación para el movimiento 9300 de Omega.
"Besides a beating heart, a watch movement also needs a place to accumulate the energy. This is where the barrel & mainspring come in. While many manufactures opt to go for multiple barrels as to enlarge the power reserve, this is not the case with Omega – although the caliber 9300 has an over-average power reserve of 60h.
So what is the point if not the lengthen the power reserve? To increase the stability of the rate over an extended period of time. In an automatic movement, the barrel is traditionally fitted with a slip clutch as to prevent over winding. In Omega’s Two Barrel system, the first barrel is constructed in the style of a manual wind movement – sans slip clutch. The second can be considered a traditional barrel for automatic movement – with slip clutch. When the first one is ‘filled’ to the max, the second one takes over.
When winding down -in other words, when the watch is running-, it first uses the energy stored in the second barrel. When that energy is equal to that of the first barrel, both will start releasing their energy simultaneously. As such, the released energy will be at a constant level for an extended period of time, thus minimizing the loss of accuracy due to decreased torque."
Parece que el primer barrilete es como el de un reloj de cuerda y el segundo como el de un automático, con embrague para evitar sobrecarga.
El segundo parece que es el que suministra el par.
Como la pregunta es interesante, y yo muy poco experto en relojes, aprovecho para subir el hilo y ver si alguien más avezado nos ilustra
Gracias por la información. Me parece muy interesante.
Entonces el primer barril, además de no tener embrague como los manuales, no se carga con el movimiento de la masa oscilante? Es manual puro y duro? Según dice omega ambos sólo trabajan simultáneamente cuando la energía acumulada en los dos es igual/similar.
Buena informacion,tambien era algo que tenia en duda,,Gracias.
En un movimiento automático el barrilete se monta con embrague (muelle sin fin que yo le llamo) para evitar sobrecargar el muelle real por exceso de carga. En el sistema de doble barrilete de Omega, el primer barrilete está diseñado como en los relojes de recarga manual, sin embrague.
El segundo barrilete puede considerarse tal cual el de un calibre automático que equipa embrague. Cuando el primero se encuentra recargado al máximo, el segundo se descarga.
Cuando se descarga, en otras palabras, cuando el reloj está funcionando, el reloj emplea en primer lugar la energía almacenada en el segundo barrilete. Cuando la energía de éste es similar a la del primer barrilete ambos liberan energía simultáneamente. Como consecuencia la energía es liberada de forma constante por un periodo prolongado de tiempo lo que minimiza la pérdida de precisión por la minoración del par.
Más o menos ésto dice.
