Josemaval
De la casa
Reloj con claras reminiscencias Sinn, viene con caja de acero y acero PVD, 44mm (en la review pone 44 pero en las especificaciones pone 42...
aunque por el nombre del modelo será de 44), calibre Etasa 2836-2, cristal de zafiro con A.R y un precio mucho más asequible que el Sinn, hablamos de unos 1.490 USD en acero y 1.590 USD con acabado Pvd.
Interesante el hecho de que se pueda personalizar en base a variaciones que ofrece la marca, viene con correa de piel con pespuntes en rojo y correa de caucho.
Info: A blog to read: http://www.ablogtoread.com/
Especificaciones:
Movement:
• ETA 2836-2, self-winding, mechanical movement
• -25 jewels
• 28,800 bph
• Shockproof according to DIN 8308
• Anti-magnetic according to DIN 8309
• Hour, minute, permanent small sweep second
• Day/Date window with new, modified position
• Regulated and Adjusted by Damasko
DA 44 Functions:
• Hour, minute, central second
• Weekday and date in new position
Case:
• Stainless steel, bead-blasted, nickel-free,
• Ice-hardened to 60 HRC or hardened to 710 HV
• Magnetic field protection up to 80,000 A/m or 100 mT integrated in casing
• Sapphire glass, bilateral anti-glare, unilateral anti-glare on request
• Glass gasket UV-resistant
• Bottom screwed with full thread, Viton O-ring gasket
• Crown sealing elements with permanent lubrication
• Viton sealing elements with maximum chemical resistance
• Crown screwable, with crown protection, crown hardened with mechanics – almost indestructable
• Crown tube screwed to casing with “System Damasko”
• Bezel hardened, rotatable in both directions with exact, ceramic-bedded minute detent, mechanics patented
• Protected from dust penetration by the sealing element
• Bezel insert hardened, PVD-coated, scratch-proof
• Choice of two swivel inserts: 60-minute countdown or 12-hour ring (in acc. with U.S.
military specifications)
• Waterproof as set out in DIN 8310, pressure-proof up to 100 bar/1.000 meters
• Vacuum-proof fitted glass
Dial:
Matt black, hour indices with white luminous compound, red index at 12
Hands:
Hour and minute with white luminous compound
Seconds hand painted with special colour in red
Strap:
• Hand made, water resistant, and silicone rubber lined black leather strap
• Bead blasted Damasko hardened buckle
Dimensions:
• Case diameter:42.00 mm
• Overall height: 12.40 mm
• Lug width: 20.00 mm
• Weight without strap: 99 grams
aunque por el nombre del modelo será de 44), calibre Etasa 2836-2, cristal de zafiro con A.R y un precio mucho más asequible que el Sinn, hablamos de unos 1.490 USD en acero y 1.590 USD con acabado Pvd.Interesante el hecho de que se pueda personalizar en base a variaciones que ofrece la marca, viene con correa de piel con pespuntes en rojo y correa de caucho.
Especificaciones:
Movement:
• -25 jewels
• 28,800 bph
DA 44 Functions:
Case:
Dial:
Hands:
Strap:
Dimensions:
, me mola mas el Sinn.
, estoy con el compañero en que el nombre de la marca no me termina, Damasko...
pero me gusta su aspecto, aunque prefiero el Sinn de calle incluso de 2ª mano.
Ostras tú, es verdad....voy a editarlo.
