demark
Hola, mi ingles no es muy bueno que digamos y por eso os pregunto a ver que entendeis vosotros, yo entiendo que se le ha roto la tija de la corona y que no tiene mas, a si que si quiero otro me lo envia, pero no se muy bien a que otro se refiere, si otro igual o otro distinto., yo habia ganado este el T91.1.483.41 ( Black Dial )".
Hi,
I'm writing to you to inform you that the watch that you have won in my auction, item # xxxxxxxxxx is having problem and I can ship it to you.
The Reason is, while my packing Dept were checking the watch, as usual to check whether it is working or not. He pulled the Crown of the watch and it came off and the spring broke. I tried to source for another piece around with my supplier but to no avail. I therefore would like to check with you whether I can replace you with another model which is T91.1.483.41 ( Black Dial ). I can sent you a photo of it if you like. Please give me your email address and I will sent you the photo of that watch.
My apologies to you for the inconvenient caused for the damage watch and hope that you can understand that sometimes this happen.
Looking forward to your kind reply.
Hi,
