Nuevo diver PRS-68, homenaje al mítico Seiko 6105
  • Iniciador del hilo Iniciador del hilo ENKI
E
ENKI
Timefactors ha puesto hoy mismo a la venta este
, que seguramente interesará a los amantes de los divers, ya que es un homenaje al mítico Seiko 6105 (el de Apocalypse Now).
Uploaded with ImageShack.us
El precio: 485 libras esterlinas.
Y las características:
[TABLE="class: tableborderlight, width: 80%, align: center"]
[TR]
[TH="class: textlge, width: 200"]MODEL
[/TH]
[TH="class: textlge"]Smiths 200 metre Automatic Diver PRS-68
[/TH]
[/TR]
[TR]
[TH="bgcolor: #FFFFCC"]
CASE​
[/TH]
[TD="bgcolor: #FFFFCC"][/TD]
[/TR]
[TR]
Material​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]316L stainless steel, brushed top with polished sides
[/TD]
[/TR]
[TR]
Diameter​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]44.5mm
[/TD]
[/TR]
[TR]
Lug to lug height​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]47mm
[/TD]
[/TR]
[TR]
Thickness​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]12.4mm to the top of the crystal
[/TD]
[/TR]
[TR]
Lug spacing​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]20mm
[/TD]
[/TR]
[TR]
Anti-magnetic​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]4,800 A/m
[/TD]
[/TR]
[TR]
Water resistance​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]20ATM/200 metres/660 feet
[/TD]
[/TR]
[TR]
Weight​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]180 grammes including bracelet, 113 grammes on "waffle" strap
[/TD]
[/TR]
[TR]
Features​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]Screw back, screw down crown, Viton case back seals, bi-directional rotating bezel with ball-bearing "click"
[/TD]
[/TR]
[TR]
[TH]
DIAL​
[/TH]
[TD="class: spectables"][/TD]
[/TR]
[TR]
[TH]
Colour​
[/TH]
[TD="class: spectables"]Black with applied indices and white printed minute track
[/TD]
[/TR]
[TR]
[TH]
Luminous​
[/TH]
[TD="class: spectables"]Applied indices and bezel pearl SuperLuminova C3
[/TD]
[/TR]
[TR]
HANDS​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"][/TD]
[/TR]
[TR]
Style​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]Bevelled rectangular, polished steel
[/TD]
[/TR]
[TR]
Luminous​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]SuperLuminova C3
[/TD]
[/TR]
[TR]
[TH]
CRYSTAL​
[/TH]
[/TR]
[TR]
[TH]
Type​
[/TH]
[TD="class: spectables"]Flat sapphire with bevelled edge and anti-reflective coating on the underside. 32mm x 3.2mm x 1.8mm
[/TD]
[/TR]
[TR]
MOVEMENT​
[/TH]
[/TR]
[TR]
Calibre​
[/TH]
[TD="class: spectables, bgcolor: #FFFFCC"]Miyota 9015, 24 jewel automatic, 28,800 BPH
[/TD]
[/TR]
[TR]
[TH]
BRACELET​
[/TH]
[TD="class: spectables"]Solid link stainless steel with screwed links and solid end links and signed clasp
[/TD]
[/TR]
[/TABLE]
Qué raro se me hace ver un calibre Miyota en esa caja. Ya puestos podrían haber puesto un NH35 como mínimo (aunque lo considere peor que el que lleva) o mejor un 6Rxx como el del Sumo.
Por ese precio me pillo uno autentico en buenas condiciones, y me dejo de copias.
Me gusta pero me lo esperaba mas barato, por ese precio voy a por el original. ¿Es edición limitada?
Anda q no....un sumo negro q quita el sentioooooo
Ya se puede poner Seiko a una reedicion, que margen y clientes tiene.
Mucho precio para el homenaje
opino lo mismo, me cogeria uno autentico estamos hablando de un Seiko no un Trolex, se me hace raro verlo ´con otra marca, yo antes me pillaba uno y lo restauraba, pero interesante hilo compañero, un saludo.
Sin duda alguna. Vendí uno hace unos meses, 100% original en todas sus piezas y en magnífico estado por algo menos de lo que cuesta esta copia. Demasiado dinero para una copia tan descarada y bastante inferior al original "homenajeado".
Que Steinhart ande haciendo "homenajes" de relojes más conocidos pues.. hasta puedo entenderlo. Es una firma relativamente nueva y, al fin y al cabo, la estrategia comercial no les ha ido mal. Pero Smith es harina de otro costal. Son muchos los años que lleva como marca relojera, y un modelo suyo subió hasta la cima del Everest..
..qué ganas de meterse en berejenales ::Dbt::
Bueno, habrá quien prefiera un reloj original con 40 años y también los habrá que prefieran el homenaje, nuevo con caja, papeles y garantía. Yo no tengo tan claro con cuál me quedaría.
Y por otro lado, Smith es una marca más de las que ha comprado el Inglés ese de Timefactors, el que también compró Precista; ya poco tiene que ver con la marca que llegó al Everest. ... (edito: me equivoqué con la traducción)
Y por otro lado, Smith es una marca más de las que ha comprado el Inglés ese de Timefactors, el que también compró Precista; ya poco tiene que ver con la marca que llegó al Everest. Con esto sólo quiero decir que la marca puede ser tan nueva o antigua como Steinhart, ahora habría que ver si Steinhart ha pagado los derechos de los relojes que homenajea, Smith lo ha hecho.
Insisto.. pagar por la copia más que por el original... ::Dbt::
No lo termino de ver...
En cuanto a lo de pagar derechos o no, a mí eso no me afecta demasiado. Por muchos royalties que pague la marca "fusiladora", al final no dejas de llevar un homenaje con mayor o menor acierto, y mejores o peores acabados.
Y que conste que tuve un Steinhart Ocean One Green que no me defraudó en absoluto el tiempo que disfruté de él. Ahora bien, hablamos de un reloj que por algo más de 300€ representa muy dignamente al original homenajeado que puede rondar de segunda mano.. ¿cuánto? ¿+- 6000€???
En ese caso lo puedo entender.
El Smith 6105 no lo veo... lo siento.. pero no ;-)
Un saludo!
Un saludo!
No es cuestión de que lo tengas que ver, yo sólo digo que uno es nuevo y el otro es un vintage, hay gente a la que le gusta estrenar el reloj y no soporta los vintages. Tampoco me afecta a mí lo de los derechos, pero como la comparaste con Steinhart ...
Lo de que cueste más que el homenajeado ... mira el Crepas Cayman, no es tan raro de ver.
Tiene muy buena pinta y no lo conocia...
Yo siempre he defendido los gustos del personal. Si prefieres un reloj nuevo homenaje, al original viejuno.. cada uno se gasta la pasta en lo que quiere ;-)
Si te he puesto el ejemplo del Steinhart, es porque vale bastante menos que el original, y por lo cuesta ofrece un buen producto. Pero también te digo que si el Ranita hubiese estado algo más bajo de precio, quizás me habría hecho con uno.
Simplemente, creo que este Smith debería valer algo menos. Por ejemplo, el Smith Everest, que homenajea al Rolex Explorer, y un reloj que me gusta bastante, sale por unas 245 libras. En este caso creo que producto/precio es más equilibrado.
Pero vamos.. es solo una opinión :)
De hecho, acabo de ver en la web que comparten movimiento.
Los relojes de Eddie Platts siempre me han gustado , el modelo Dreadnought fue no solo un rotundo suceso, sino que es uno de los pocos relojes que he visto cojer valor con el tiempo, y casi imposible de obtener en estos dias.
Los precios siempre han sido muy altos en mi opinion, aunque se cita que sus cajas son hechas por Ickler etc. etc justificar un reloj que lleva un movimiento que cuesta menos de $100 dolares en ese precio es dificil .
Creo que Dagaz compite con Timefactor favorablemente, tiene modelos muy similares y de igual calidad por mucho menos ....
Yo lo veo perfectamente justificable. Mirad vuestra caja de relojes, los calibres que llevan y lo que valen nuevos, no lo que os costó.
Te puedes pillar los dos, no es cuestión de elegir uno u otro forzosamente.
Opino como el resto de compañeros. Un homenaje demasiado caro en comparación con el original.
También los 2824 y se montan en relojes de miles de €...
Respecto al reloj, no me gusta, al igual que el original, además lo veo alto de precio, cuando el concepto del homenaje se supone que es pagar menos de lo que cuesta el original, y tener su estética, sea con Parnis, Steinhart, Helson, etc.
Evidentemente PRS no tiene departamento de diseño o sus responsables andan faltos de ideas desde hace ya mucho.
En fin......que lo compre quien le guste.
De acuerdo ...pero yo en particular, no pago miles de €'s por ninguno, ya sea ETA o Miyota, especialmente cuando existen tantas posibilidades de elegir...la competencia es dura;-)
Respecto al reloj, estamos completamente de acuerdo , como decia anteriormente ....en general me gusta lo que hace Eddie Platts , pero no sus precios.
A mi los relojes homenaje no me van en lo más mínimo. Son simples copias. Por favor, algo de ingenio!!!
