Jesús
Gran Cruz al Mérito Forero
Coger un Escort Mk I de 1973, desnudarlo hasta la carrocería y a partir de ahí reconstruirlo con componentes modernos. Por ejemplo...
Ford Duratec 2.0 engine, target 280bhp at crank
12.4:1 compression ratio, full race cams, Arrow conrods, CNC ported head, dry sump
2007 Mazda MX5 6-speed gearbox, lightweight flywheel and clutch
Jenvey 48mm independent throttle bodies, Emerald K6 ECU
Atlas axle with Quaife ATB
Front Brembo Racing calipers on 295mm Brembo vented discs, rear discs and calipers
15x8 Compomotive wheels
Coil over suspension on front with compression struts and adjustable TRAs
Turrets and coilover suspension rear, four-link rear axle location along with Watts link
Full weld in cage, plumbed in fire extinguisher.
Quizás sea una herejía, pero...
https://www.crankandpiston.com/ford-escort-mk1-reborn-in-dubai/
