Relojes Damasko
  • Iniciador del hilo Iniciador del hilo tuko
tuko
tuko
Acabo de "descubrir" estos relojes....¿alguno podéis dar alguna información?.
Por lo que he visto en su página web tienen algún modelo parecido a Sinn?
Los precios, desde mi punto de vista, quizás son un poco elevados.
¿Qué opináis? Pongo alguna foto :
Movement:
Valjoux 7750
self-winding, mechanical movement
25 jewels
28,800 bph
Shockproof according to DIN 8308
Anti-magnetic according to DIN 8309
DC66 functions:
Hour, minute, permanent small sweep second
Day/Date window with new, modified position
Chronograph: 12-hour counter and 30-minute counter on sub-dials, central 60-second counter
Case:
-Stainless steel, nickel-free, bead-blasted, finished with extremely abrasion-proof Damest layer
-Ice-hardened to 60 HRC or 710 Vickers
-Integrated anti-magnetic inner cage, anti-magnetic to 80,000 A/m or 100 mT
-Sapphire crystal with anti-reflective coating on both sides, AR coating on the underside only, available on special request
-Crystal gasket resistant to UV radiation
-Solid screw back with O-ring Viton™ gasket
-All gaskets made from Viton™ which offers a premium chemical resistance and which is superior to most other materials used in the watch industry
-New patented crown and pusher system, crown stem and pusher shafts are machined with minimal tolerances and leave almost no gap between pusher/crown and case, but nevertheless do not scratch. Crown and pushers are also equipped with a permanent lubrication that eliminates friction
-Screw-down crown with protective shoulders
-Crown, pushers, and tubes hardened to 60 HRC
-Bi-directional rotating bezel with exact minute engagement working with patented ceramic bearing
-Sealed luminous dot
-Protected from the intrusion of dust by gasket element
-Hardened and scratchproof bezel insert finished with extremely abrasion-proof Damest layer with a hardness of 2500 HV
-Two optional bezel inserts: 60-minute countdown or 12-hour ring (according to US military specifications)
-Water resistant to 10 bars/100 metres according to DIN 8310
-Crystal has a secure fit even in case of a sudden negative pressure
Me suena haber leído que fueron la misma empresa Sinn y Damasko, de ahí vendrán sus parecidos.
Los precios pues vaya, dado que usan el acero especial endurecido y demás sistemas, pues bueno tampoco se van mucho los de calibres básicos. Seguro que no defraudan en cuanto a calidad.
