Niven
Antiguos Moderadores
Buscando por Emule he encontrado esto, a ver como sale.
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
Manual Winding
· Lange: L 902 has a tourbillon and wind indicator.
· Lemania: 387 has a tourbillon; 1873 is a chronograph with 30-minutes counter and small seconds dial; 1874 has 30-minutes- and 12-hours-dials, 1883 has additional date and phase of the moon indicators. 2310 is a chronograph with 30-minutes-dial, 2612 has additional 12-hours, date- and moon phase-dials.
· Patek Philippe: RTO 27 PS is a watch enthusiast's dream come true: a minute repeater with tourbillon. CH 27-70 Q is a chronograph with perpetual calendar (day, date, month, leap year, moon phase) and 24-hour display.
· Piaget: 2P and 6N have the crown on the back of the watch.
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
Automatic
· ETA: 2824-2 and 2836-2 are based on ETA 2801. 2834-2, based on 2824-2, has an additional day-of-the-week display.
· GUB: 10-30 is the base calibre for GUB 10-60 which has an additional chronograph module (diameter 31.15 mm, height 7.2 mm, 48 jewels).
· Jaeger-LeCoultre: 919 is the only calibre that incorporates an alarm and a perpetual calendar including display of the year in digits.
· Lemania: 1350 is a chronograph with (central) 60 minutes- and 12 hour-dials. Additional versions are available with, e.g., power reserve indicator or perpetual calendar. 2010 holds a record: it is the slimmest automatic calibre in the world (use of ball-bearings instead of jewels). 5100 is a chronograph with 24-hour display. 8810 is available in different versions, including perpetual calendar, power reserve indicator, second time zone etc. (height varies accordingly between 2.95 and 5.45 mm).
· Omega: All calibres of the 1120 series are certified chronometers.
· Piaget: 12P1 has a 24 ct gold micro-rotor.
· Piguet: 1185 is the slimmest chronograph movement in the world. It is the base for the 1186 "chronographe rattrapante" (split seconds chronograph). 1195 is a certified chronometer.
· Rolex: 2130 is a variant of the 2135 shown above without date (height 5.4 mm). 3135 is the base for 3155 (day and date), 3175 (24-hour display) and 3185 (time zone indicator). All of the 31.5 series are certified chronometers.
· Valjoux/ETA: 7750/51 is a chronograph with small second, 30-minutes- and 12-hours-indicator. Different versions available, e.g., perpetual calendar, power reserve indicator.
· Zenith: 400 is a chronograph with 1/10 second accuracy and date display. 410 shows day, date, month and moon phase, otherwise identical. There are different versions of the "Elite" caliber: 660 (date), 661 (hours and minutes), 672 (central second and 24-hour-display), 680 (small second and 24-hour-display).
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<TABLE class=MsoNormalTable style="MARGIN: auto auto auto 4.5pt; BORDER-COLLAPSE: collapse; mso-table-layout-alt: fixed; mso-padding-alt: 0cm 4.5pt 0cm 4.5pt" cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: windowtext 2.25pt ridge; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 297.7pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt" width=397>
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: windowtext 2.25pt ridge; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 184.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt" width=246>· Philip
· Sector
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 184.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=246>independent
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 184.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=246>· Chaumon
· Ebel
· Favre-Leuba
· Tag Heuer
· Zenith
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 184.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=246>· Concord
· Movado
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 184.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=246>· Baume & Mercier
· Cartier
· IWC
· Jaeger-LeCoultre
· Piaget
· Vacheron Constantin
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 184.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=246>· Chopard
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 184.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=246>· Blancpain
· Breguet
· Calvin Klein
· Certina
· Eta (Movements)
· Longines
· Omega
· Rado
· Swatch
· Tissot
</TD></TR></TBODY></TABLE>
<o😛></o😛>Artime<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o😛></o😛>
· Sector
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 297.7pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=397>Audemars Piguet<o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 297.7pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=397>Breitling<o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 297.7pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=397>LVMH
Louis Vuitton - Moët - Hennessy
(France)<o😛></o😛>
(France)<o😛></o😛>
· Ebel
· Favre-Leuba
· Tag Heuer
· Zenith
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 297.7pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=397>North American Watch
(USA)<o😛></o😛>
· Movado
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 297.7pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=397>Patek Philippe<o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 297.7pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=397>Richemont<o😛></o😛>
· Cartier
· IWC
· Jaeger-LeCoultre
· Piaget
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 297.7pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=397>Rolex<o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 297.7pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=397>Scheufele
(Germany)<o😛></o😛>
</TD></TR><TR style="mso-yfti-lastrow: yes"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 4.5pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 4.5pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 297.7pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=397>Swatch Group<o😛></o😛>
· Breguet
· Calvin Klein
· Certina
· Eta (Movements)
· Longines
· Omega
· Rado
· Swatch
· Tissot
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
Manual Winding
<TABLE class=MsoNormalTable style="MARGIN: auto auto auto 1.15pt; BORDER-COLLAPSE: collapse; mso-table-layout-alt: fixed; mso-padding-alt: 0cm 0cm 0cm 0cm" cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: windowtext 2.25pt ridge; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt" width=113>
</TD></TR><TR style="mso-yfti-irow: 2"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Audemars Piguet 2003
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1946
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.8
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1.64
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>18
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>38 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Audemars Piguet
</TD></TR><TR style="mso-yfti-irow: 3"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Chronoswiss C 111
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1995
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>29.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>3.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>17
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>47 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Chronoswiss
</TD></TR><TR style="mso-yfti-irow: 4"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>ETA 2660
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1971
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>17.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>3.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>44 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>BWC, Laco, Raymond Weil
</TD></TR><TR style="mso-yfti-irow: 5"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>ETA 2691
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1988
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>19.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Oris
</TD></TR><TR style="mso-yfti-irow: 6"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>ETA 2801-2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1982
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>25.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>3.35
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>46 h
</TD></TR><TR style="mso-yfti-irow: 7"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>ETA 7001
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>23.3
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>42 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Baume & Mercier, Bucherer, Chronoswiss, Cogito, Gerald Genta, Laco, Landier, Louis Erard, Maurice Lacroix, Michel Herbelin, Milus, M & M, Movado, Nivrel, Nomos, Omega, Paul Picot, Pequignet, Ulysse Nardin
</TD></TR><TR style="mso-yfti-irow: 8"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>GUB 12-50
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1994
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>3.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Glashütter Uhrenbetrieb (GUB)
</TD></TR><TR style="mso-yfti-irow: 9"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>GUB 50
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>25.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>5.9
</TD></TR><TR style="mso-yfti-irow: 10"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Jaeger-LeCoultre 803
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1951
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Vacheron Constantin
</TD></TR><TR style="mso-yfti-irow: 11"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Jaeger-LeCoultre 818/4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1959
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2.94
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>40 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Chopard, Jaeger-LeCoultre, Vacheron Constantin
</TD></TR><TR style="mso-yfti-irow: 12"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Jaeger-LeCoultre 822
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1992
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>22.6 x 17.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>23
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>45 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Jaeger-LeCoultre
</TD></TR><TR style="mso-yfti-irow: 13"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Jaeger-LeCoultre 838/839
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1962
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1.84
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>36 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Chopard, IWC, Jaeger-LeCoultre
</TD></TR><TR style="mso-yfti-irow: 14"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Jaeger-LeCoultre 846
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1975
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>15.2 x 13.0
</TD></TR><TR style="mso-yfti-irow: 15"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lange L 901
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>30.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>53
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>100 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>A. Lange & Söhne
</TD></TR><TR style="mso-yfti-irow: 16"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lange L 902
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>30.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>6.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>29
</TD></TR><TR style="mso-yfti-irow: 17"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lange L 911.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>25.6 x 17.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>30
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>48 h
</TD></TR><TR style="mso-yfti-irow: 18"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lange L 941.1
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1996
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>21
</TD></TR><TR style="mso-yfti-irow: 19"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lemania 387
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1987
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>30.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>4.8
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>50 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Alain Silberstein, Breguet, Vacheron Constantin
</TD></TR><TR style="mso-yfti-irow: 20"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lemania 1210
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1981
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>11
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Sarcar
</TD></TR><TR style="mso-yfti-irow: 21"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lemania 1872/1873/1874/1883
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1961 (1883 since 1983)
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>27.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1872: 5.7
1873/74/83: 6.87
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Baume & Mercier, Breitling, Chopard, Loran of Switzerland, Mercedes, Minerva, Omega, Sinn, Universal Genève, Wehrle, Schwarz-Etienne
</TD></TR><TR style="mso-yfti-irow: 22"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lemania 2310/2612
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1942
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2310: 1.64
2612: 6.74
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Breguet, Ulysse Nardin
</TD></TR><TR style="mso-yfti-irow: 23"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Patek Philippe 16-250
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>16.3
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Patek Philippe
</TD></TR><TR style="mso-yfti-irow: 24"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Patek Philippe RTO 27 PS
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1989
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>28.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>6.55
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>28
</TD></TR><TR style="mso-yfti-irow: 25"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Patek Philippe CH 27-70 Q
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1986
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>27.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>7.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>24
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>60 h
</TD></TR><TR style="mso-yfti-irow: 26"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Patek Philippe 177
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1974
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1.77
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>43 h
</TD></TR><TR style="mso-yfti-irow: 27"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Patek Philippe 215
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>21.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2.55
</TD></TR><TR style="mso-yfti-irow: 28"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piaget 2P
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1954
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>17.0 x 8.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Piaget
</TD></TR><TR style="mso-yfti-irow: 29"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piaget 40 P
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>14.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>19
</TD></TR><TR style="mso-yfti-irow: 30"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piaget 6N
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1956
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>13.5
</TD></TR><TR style="mso-yfti-irow: 31"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piaget 9P2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1958
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2.15
</TD></TR><TR style="mso-yfti-irow: 32"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piguet 6.10
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1993
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>15.7
</TD></TR><TR style="mso-yfti-irow: 33"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piguet 8.10
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1990
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>18.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>20
</TD></TR><TR style="mso-yfti-irow: 34"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piguet 21
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1925
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1.73
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>18
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Bertolucci, Blancpain, Bucherer, Bunz, Cartier, Chopard, Corum, Sarcar
</TD></TR><TR style="mso-yfti-irow: 35"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Rolex 1400
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1960
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>13.75
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>3.23
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Rolex
</TD></TR><TR style="mso-yfti-irow: 36"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Rolex 1600/1601
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1600: 1964
1601: 1977
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.8
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1600: 2.32
1601: 2.35
</TD></TR><TR style="mso-yfti-irow: 37"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Valjoux/ETA 7760
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1985
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>7.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>17
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>44 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Audi, Christ, Raymond Weil, Tutima
</TD></TR><TR style="mso-yfti-lastrow: yes; mso-yfti-irow: 38"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Zenith 420
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>5.7
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>25
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>55 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Zenith
</TD></TR></TBODY></TABLE>
· Jaeger-LeCoultre: 822 is based on 824; 822 and 846 are tonneau-shaped. There are other 818 versions: 818/5 with 21 jewels and fine adjustment and 819 with central seconds hand.Caliber<o😛></o😛>
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: windowtext 2.25pt ridge; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 14cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt" width=529 colSpan=6>
Technical Data<o😛></o😛>
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>
Name<o😛></o😛>
produced since<o😛></o😛>
Diameter [mm]<o😛></o😛>
Height [mm]<o😛></o😛>
Jewels<o😛></o😛>
Power Reserve<o😛></o😛>
Used by<o😛></o😛>
</TD></TR><TR style="mso-yfti-irow: 2"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Audemars Piguet 2003
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1946
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1.64
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>38 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Audemars Piguet
</TD></TR><TR style="mso-yfti-irow: 3"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Chronoswiss C 111
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1995
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>29.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>47 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Chronoswiss
</TD></TR><TR style="mso-yfti-irow: 4"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>ETA 2660
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1971
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>17.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>3.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>BWC, Laco, Raymond Weil
</TD></TR><TR style="mso-yfti-irow: 5"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>ETA 2691
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1988
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>19.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Oris
</TD></TR><TR style="mso-yfti-irow: 6"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>ETA 2801-2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1982
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>3.35
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>46 h
</TD></TR><TR style="mso-yfti-irow: 7"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>ETA 7001
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>23.3
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>42 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Baume & Mercier, Bucherer, Chronoswiss, Cogito, Gerald Genta, Laco, Landier, Louis Erard, Maurice Lacroix, Michel Herbelin, Milus, M & M, Movado, Nivrel, Nomos, Omega, Paul Picot, Pequignet, Ulysse Nardin
</TD></TR><TR style="mso-yfti-irow: 8"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>GUB 12-50
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1994
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>3.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Glashütter Uhrenbetrieb (GUB)
</TD></TR><TR style="mso-yfti-irow: 9"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>GUB 50
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>25.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>5.9
</TD></TR><TR style="mso-yfti-irow: 10"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Jaeger-LeCoultre 803
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1951
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Vacheron Constantin
</TD></TR><TR style="mso-yfti-irow: 11"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Jaeger-LeCoultre 818/4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1959
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2.94
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>40 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Chopard, Jaeger-LeCoultre, Vacheron Constantin
</TD></TR><TR style="mso-yfti-irow: 12"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Jaeger-LeCoultre 822
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1992
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>22.6 x 17.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>23
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>45 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Jaeger-LeCoultre
</TD></TR><TR style="mso-yfti-irow: 13"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Jaeger-LeCoultre 838/839
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1962
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1.84
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>36 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Chopard, IWC, Jaeger-LeCoultre
</TD></TR><TR style="mso-yfti-irow: 14"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Jaeger-LeCoultre 846
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1975
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>15.2 x 13.0
</TD></TR><TR style="mso-yfti-irow: 15"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lange L 901
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>30.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>53
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>100 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>A. Lange & Söhne
</TD></TR><TR style="mso-yfti-irow: 16"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lange L 902
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>30.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>6.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>29
</TD></TR><TR style="mso-yfti-irow: 17"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lange L 911.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>25.6 x 17.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>30
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>48 h
</TD></TR><TR style="mso-yfti-irow: 18"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lange L 941.1
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1996
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>21
</TD></TR><TR style="mso-yfti-irow: 19"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lemania 387
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1987
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>30.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>4.8
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>50 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Alain Silberstein, Breguet, Vacheron Constantin
</TD></TR><TR style="mso-yfti-irow: 20"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lemania 1210
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1981
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>11
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Sarcar
</TD></TR><TR style="mso-yfti-irow: 21"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lemania 1872/1873/1874/1883
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1961 (1883 since 1983)
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>27.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1872: 5.7
1873/74/83: 6.87
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Baume & Mercier, Breitling, Chopard, Loran of Switzerland, Mercedes, Minerva, Omega, Sinn, Universal Genève, Wehrle, Schwarz-Etienne
</TD></TR><TR style="mso-yfti-irow: 22"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Lemania 2310/2612
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1942
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2310: 1.64
2612: 6.74
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Breguet, Ulysse Nardin
</TD></TR><TR style="mso-yfti-irow: 23"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Patek Philippe 16-250
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>16.3
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Patek Philippe
</TD></TR><TR style="mso-yfti-irow: 24"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Patek Philippe RTO 27 PS
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1989
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>28.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>6.55
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>28
</TD></TR><TR style="mso-yfti-irow: 25"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Patek Philippe CH 27-70 Q
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1986
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>27.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>7.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>24
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>60 h
</TD></TR><TR style="mso-yfti-irow: 26"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Patek Philippe 177
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1974
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1.77
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>43 h
</TD></TR><TR style="mso-yfti-irow: 27"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Patek Philippe 215
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>21.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2.55
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>18
</TD></TR><TR style="mso-yfti-irow: 28"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piaget 2P
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1954
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>17.0 x 8.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Piaget
</TD></TR><TR style="mso-yfti-irow: 29"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piaget 40 P
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>14.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>19
</TD></TR><TR style="mso-yfti-irow: 30"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piaget 6N
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1956
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>13.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>3.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>17
</TD></TR><TR style="mso-yfti-irow: 31"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piaget 9P2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1958
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.8
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>2.15
</TD></TR><TR style="mso-yfti-irow: 32"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piguet 6.10
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1993
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>15.7
</TD></TR><TR style="mso-yfti-irow: 33"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piguet 8.10
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1990
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>18.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>20
</TD></TR><TR style="mso-yfti-irow: 34"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Piguet 21
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1925
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1.73
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Bertolucci, Blancpain, Bucherer, Bunz, Cartier, Chopard, Corum, Sarcar
</TD></TR><TR style="mso-yfti-irow: 35"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Rolex 1400
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1960
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>13.75
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>3.23
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>44 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Rolex
</TD></TR><TR style="mso-yfti-irow: 36"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Rolex 1600/1601
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1600: 1964
1601: 1977
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>1600: 2.32
1601: 2.35
</TD></TR><TR style="mso-yfti-irow: 37"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Valjoux/ETA 7760
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 35.45pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=47>1985
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>7.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Audi, Christ, Raymond Weil, Tutima
</TD></TR><TR style="mso-yfti-lastrow: yes; mso-yfti-irow: 38"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=113>Zenith 420
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 49.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=66>5.7
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>25
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>55 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 148.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=198>Zenith
</TD></TR></TBODY></TABLE>
· Lange: L 902 has a tourbillon and wind indicator.
· Lemania: 387 has a tourbillon; 1873 is a chronograph with 30-minutes counter and small seconds dial; 1874 has 30-minutes- and 12-hours-dials, 1883 has additional date and phase of the moon indicators. 2310 is a chronograph with 30-minutes-dial, 2612 has additional 12-hours, date- and moon phase-dials.
· Patek Philippe: RTO 27 PS is a watch enthusiast's dream come true: a minute repeater with tourbillon. CH 27-70 Q is a chronograph with perpetual calendar (day, date, month, leap year, moon phase) and 24-hour display.
· Piaget: 2P and 6N have the crown on the back of the watch.
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
Automatic
<TABLE class=MsoNormalTable style="MARGIN: auto auto auto 1.15pt; BORDER-COLLAPSE: collapse; mso-table-layout-alt: fixed; mso-padding-alt: 0cm 0cm 0cm 0cm" cellSpacing=0 cellPadding=0 border=0><TBODY><TR style="mso-yfti-irow: 0"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: windowtext 2.25pt ridge; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt" width=85>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Audemars Piguet 2121
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1967
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>2.45
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>36
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Audemars Piguet, Vacheron Constantin
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Audemars Piguet 2125
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1983
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>26.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.25
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>33
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Audemars Piguet 2140
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1994
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.95
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>31
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>40 h
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>AS 5008
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1973
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>7.25
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>17
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Maurice Lacroix (modified version ML20/AS 5008), Pequignet, Ulysse Nardin
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Chopard LUC 1/96
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1996
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.3
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>29
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>65 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Chopard
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Chronoswiss C 122
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1991
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>26.77
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Chronoswiss
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2000
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1992
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>19.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>20
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>45 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Baume & Mercier, Bertolucci, Chronoswiss, Cyclus, Eterna, Schwarz-Etienne, Universal Genève
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2671
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1971
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>17.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>4.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>25
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Alain Silberstein, Alpina, Auguste Reymond, Cartier, Delma, Eterna, Maurice Lacroix, Oris
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2688
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1986
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.35
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Oris
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2824-2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1982
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>25.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>4.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>38 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Auguste Reymond, Cartier, Dugena, Eterna, Festina, Fortis, Gaddy's, Kienzle, Maurice Lacroix, MHR, Motochron, Oris, Schwarz-Etienne, TAG-Heuer, Tissot
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2836-2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.05
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Maurice Lacroix, Mido, Tutima
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2840
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>25.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>23
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>49 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Swatch
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2892-2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>21
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>42 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Alain Silberstein, Auguste Reymond, Baume & Mercier, Breitling, Bulgari, Dugena, Ebel, Eberhard, Eterna, Forget, Fortis, Girard-Perregaux, Harwood, Hublot, Jaguar, Kelek, Longines, Maurice Lacroix, Mido, Omega, Paul Picot, Rainer Brand, Raymond Weil, Schwarz-Etienne, Sinn, TAG-Heuer, Tiffany, Ulysse Nardin, Universal Genève, Zenith
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Girard-Perregaux 3100
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>26.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>2.98
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>27
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>50 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Bulgari, Girard-Perregaux
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>GUB 10-30
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1993
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>4.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>22
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Glashütter Uhrenbetrieb (GUB)
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>IWC 8541
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1964
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>28.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>IWC
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Jaeger-LeCoultre 889/1
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1989
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Audemars Piguet, Chopard, IWC, Jaeger-LeCoultre, Vacheron Constantin
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Jaeger-LeCoultre 919
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>30.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>8.3
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Jaeger-LeCoultre
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Jaeger-LeCoultre 960
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1995
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>IWC, Jaeger-LeCoultre
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Lemania 1350
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>31.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>6.95
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>30
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Ebel
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Lemania 1910
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>23.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>26
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Breguet, Ebel
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Lemania 2010
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1978 by Lassale, since 1993 by Lemania
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.8
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>2.08
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>11 (plus 18 ball-bearings)
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Piaget, Sarcar
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Lemania 5100
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1974
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>8.25
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>48 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Fortis, Key West, Omega, Sinn, Tutima
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Lemania 8810
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>2.95
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Bertolucci, Breguet
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Miyota 8215
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1977
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.32
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Camel, Citizen, Dugena, Festina
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Patek Philippe 240 PS
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1985
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>27.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Patek Philippe
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Patek Philippe 315SC/330SC
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.22
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Omega 1120
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>44 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Omega
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piaget 12P1
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1957
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>?? h
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piguet 9'''
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>19
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Blancpain, Chopard
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piguet 11.50
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1988
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>100 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Blancpain, Chopard, Corum
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piguet 71P
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>27.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>2.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>35
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Breguet, Cartier, Chopard, Gerald Genta, IWC, Kurt Schaffo, Ulysse Nardin, Urban Jürgensen
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piguet 1185
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>37
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Blancpain, Breitling, Piaget
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piguet 1195
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>4.5
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Rolex 2135
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1984
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.83
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Rolex
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Rolex 3000
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>28.5
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Rolex 3135
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>6.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>31
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Rolex 4030
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>6.5
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Seiko 7009 A
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1970
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>17
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>47 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Seiko
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Valjoux/ETA 7750/51
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1973
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>7.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>46 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Alain Silberstein, Auguste Reymond, Bertolucci, Breitling, Christ, Chronoswiss, Dugena, Eberhard, Eterna, Forget, IWC, Jaguar, Kelek, Longines, M & M, Maurice Lacroix, Minerva, Omega, Oris, Paul Picot, Raymond Weil, Schwarz-Etienne, Sector, Sinn, TAG-Heuer, Tissot, Ulysse Nardin, Universal Genève
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Zenith 400/410
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1969
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>6.5/7.55
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Dunhill, Kurt Schaffo, Officine Panerai, Zenith. Base for old Rolex "Cosmograph Daytona."
</TD></TR><TR style="mso-yfti-lastrow: yes"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Zenith "Elite"
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1994
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.28
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>55 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Zenith, Officine Panerai
</TD></TR></TBODY></TABLE>
· AS 5008 is an alarm calibre with two spring housings. The Maurice Lacroix version ML20/AS 5008 has a ball-bearing rotor and 31 jewels. Caliber<o😛></o😛>
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: windowtext 2.25pt ridge; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 15cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt" width=567 colSpan=6>
Technical Data<o😛></o😛>
Name<o😛></o😛>
produced since<o😛></o😛>
Diameter [mm]<o😛></o😛>
Height [mm]<o😛></o😛>
Jewels<o😛></o😛>
Power Reserve<o😛></o😛>
Used by<o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Audemars Piguet 2121
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1967
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>2.45
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>36
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>45 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Audemars Piguet, Vacheron Constantin
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Audemars Piguet 2125
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1983
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>26.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.25
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>33
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Audemars Piguet 2140
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.95
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>40 h
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>AS 5008
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>7.25
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>36 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Maurice Lacroix (modified version ML20/AS 5008), Pequignet, Ulysse Nardin
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Chopard LUC 1/96
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1996
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>25.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.3
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>29
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>65 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Chopard
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Chronoswiss C 122
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1991
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>26.77
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Chronoswiss
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2000
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1992
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>19.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>20
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Baume & Mercier, Bertolucci, Chronoswiss, Cyclus, Eterna, Schwarz-Etienne, Universal Genève
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2671
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1971
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>17.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>4.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>25
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Alain Silberstein, Alpina, Auguste Reymond, Cartier, Delma, Eterna, Maurice Lacroix, Oris
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2688
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1986
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.35
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Oris
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2824-2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1982
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>4.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>38 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Auguste Reymond, Cartier, Dugena, Eterna, Festina, Fortis, Gaddy's, Kienzle, Maurice Lacroix, MHR, Motochron, Oris, Schwarz-Etienne, TAG-Heuer, Tissot
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2836-2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.05
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Maurice Lacroix, Mido, Tutima
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2840
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>25.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>23
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>49 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Swatch
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>ETA 2892-2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>21
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>42 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Alain Silberstein, Auguste Reymond, Baume & Mercier, Breitling, Bulgari, Dugena, Ebel, Eberhard, Eterna, Forget, Fortis, Girard-Perregaux, Harwood, Hublot, Jaguar, Kelek, Longines, Maurice Lacroix, Mido, Omega, Paul Picot, Rainer Brand, Raymond Weil, Schwarz-Etienne, Sinn, TAG-Heuer, Tiffany, Ulysse Nardin, Universal Genève, Zenith
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Girard-Perregaux 3100
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>26.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>2.98
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>27
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>50 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Bulgari, Girard-Perregaux
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>GUB 10-30
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1993
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>4.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>22
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Glashütter Uhrenbetrieb (GUB)
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>IWC 8541
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1964
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>28.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>IWC
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Jaeger-LeCoultre 889/1
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1989
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Audemars Piguet, Chopard, IWC, Jaeger-LeCoultre, Vacheron Constantin
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Jaeger-LeCoultre 919
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>30.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>8.3
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>44 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Jaeger-LeCoultre
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Jaeger-LeCoultre 960
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1995
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>IWC, Jaeger-LeCoultre
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Lemania 1350
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>31.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>6.95
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>30
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Ebel
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Lemania 1910
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>23.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>26
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Breguet, Ebel
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Lemania 2010
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1978 by Lassale, since 1993 by Lemania
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.8
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>2.08
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>11 (plus 18 ball-bearings)
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Piaget, Sarcar
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Lemania 5100
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1974
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>8.25
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>48 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Fortis, Key West, Omega, Sinn, Tutima
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Lemania 8810
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>2.95
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Bertolucci, Breguet
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Miyota 8215
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1977
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.32
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Camel, Citizen, Dugena, Festina
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Patek Philippe 240 PS
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1985
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>27.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Patek Philippe
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Patek Philippe 315SC/330SC
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.22
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Omega 1120
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Omega
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piaget 12P1
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1957
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.0
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>?? h
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piguet 9'''
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>20.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>19
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Blancpain, Chopard
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piguet 11.50
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1988
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>31
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>100 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Blancpain, Chopard, Corum
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piguet 71P
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>27.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>2.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>35
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Breguet, Cartier, Chopard, Gerald Genta, IWC, Kurt Schaffo, Ulysse Nardin, Urban Jürgensen
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piguet 1185
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.4
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>37
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Blancpain, Breitling, Piaget
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Piguet 1195
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>4.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>45 h
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Rolex 2135
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1984
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>5.83
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Rolex
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Rolex 3000
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>28.5
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Rolex 3135
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>6.0
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Rolex 4030
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>6.5
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Seiko 7009 A
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1970
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=57>17
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>47 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Seiko
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Valjoux/ETA 7750/51
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1973
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>7.9
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>46 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Alain Silberstein, Auguste Reymond, Bertolucci, Breitling, Christ, Chronoswiss, Dugena, Eberhard, Eterna, Forget, IWC, Jaguar, Kelek, Longines, M & M, Maurice Lacroix, Minerva, Omega, Oris, Paul Picot, Raymond Weil, Schwarz-Etienne, Sector, Sinn, TAG-Heuer, Tissot, Ulysse Nardin, Universal Genève
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Zenith 400/410
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1969
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>6.5/7.55
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Dunhill, Kurt Schaffo, Officine Panerai, Zenith. Base for old Rolex "Cosmograph Daytona."
</TD></TR><TR style="mso-yfti-lastrow: yes"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>Zenith "Elite"
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>1994
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=85>25.6
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>3.28
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=76>55 h
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 5cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=189>Zenith, Officine Panerai
</TD></TR></TBODY></TABLE>
· ETA: 2824-2 and 2836-2 are based on ETA 2801. 2834-2, based on 2824-2, has an additional day-of-the-week display.
· GUB: 10-30 is the base calibre for GUB 10-60 which has an additional chronograph module (diameter 31.15 mm, height 7.2 mm, 48 jewels).
· Jaeger-LeCoultre: 919 is the only calibre that incorporates an alarm and a perpetual calendar including display of the year in digits.
· Lemania: 1350 is a chronograph with (central) 60 minutes- and 12 hour-dials. Additional versions are available with, e.g., power reserve indicator or perpetual calendar. 2010 holds a record: it is the slimmest automatic calibre in the world (use of ball-bearings instead of jewels). 5100 is a chronograph with 24-hour display. 8810 is available in different versions, including perpetual calendar, power reserve indicator, second time zone etc. (height varies accordingly between 2.95 and 5.45 mm).
· Omega: All calibres of the 1120 series are certified chronometers.
· Piaget: 12P1 has a 24 ct gold micro-rotor.
· Piguet: 1185 is the slimmest chronograph movement in the world. It is the base for the 1186 "chronographe rattrapante" (split seconds chronograph). 1195 is a certified chronometer.
· Rolex: 2130 is a variant of the 2135 shown above without date (height 5.4 mm). 3135 is the base for 3155 (day and date), 3175 (24-hour display) and 3185 (time zone indicator). All of the 31.5 series are certified chronometers.
· Valjoux/ETA: 7750/51 is a chronograph with small second, 30-minutes- and 12-hours-indicator. Different versions available, e.g., perpetual calendar, power reserve indicator.
· Zenith: 400 is a chronograph with 1/10 second accuracy and date display. 410 shows day, date, month and moon phase, otherwise identical. There are different versions of the "Elite" caliber: 660 (date), 661 (hours and minutes), 672 (central second and 24-hour-display), 680 (small second and 24-hour-display).
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
<TABLE class=MsoNormalTable style="MARGIN: auto auto auto 1.15pt; BORDER-COLLAPSE: collapse; mso-table-layout-alt: fixed; mso-padding-alt: 0cm 0cm 0cm 0cm" cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: windowtext 2.25pt ridge; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt" width=85>
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=4>Baume & Mercier
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>BM 8395
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2000
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>BM 11892
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2892-A2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>BM 13283
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 283, module caliber
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>BM 13750
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7750
</TD></TR><TR style="mso-yfti-irow: 6"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=3>Breitling
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Breitling 10, 19, 30, 26, 39, 40
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Breitling Caliber 12
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 1877
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Breitling Caliber 13
</TD></TR><TR style="mso-yfti-irow: 10"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=5>Bvlgari
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MVA 060
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>GP 8293
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MVA 900
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>GP 8290
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MVT 3002 I
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>GP Manufacture 3002
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MVT 9902 TB
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>GP 9902
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MVT R 220 R
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>GP Manufacture 220
</TD></TR><TR style="mso-yfti-irow: 16"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=12>Cartier
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 021
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 21P
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 048
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2893
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 049, 149
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 077
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2671
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 078
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2512
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 096
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 99P
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 191
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Girard-Perregaux GP 3100
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 200, 220
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 205
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 1185
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 430 C
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Piaget 430P
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier VC 200043
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Piaget 212
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier VC 200049
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Piaget 9P2
</TD></TR><TR style="mso-yfti-irow: 29"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=2>Chronoswiss
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Chronoswiss C.732, C.741, C.741 S,
C.753, C.754, C.755
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 7750
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>C.1722 R
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Minerva 1722
</TD></TR><TR style="mso-yfti-irow: 32"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Corum
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Corum 58
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 70
</TD></TR><TR style="mso-yfti-irow: 34"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=4>Ebel
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Ebel 080
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 8810
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Ebel 124
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Ebel 136
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Zenith El Primero 400
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Ebel 964
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 9.51
</TD></TR><TR style="mso-yfti-irow: 39"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=2>Louis Erard
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ER 48, ER 51
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Peseux 7001
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ER 57, ER 61
</TD></TR><TR style="mso-yfti-irow: 42"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Fortis
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>F 2001
</TD></TR><TR style="mso-yfti-irow: 44"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Gevril
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>BO111, CO111
</TD></TR><TR style="mso-yfti-irow: 46"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=5>IWC
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>IWC C.849
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Jaeger-LeCoultre 849
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>IWC C.884/2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Jaeger-LeCoultre 889
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>IWC C.887/2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Jaeger-LeCoultre 887/2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>IWC C.891/2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Jaeger-LeCoultre 891/2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>IWC C.960
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Jaeger-LeCoultre 960
</TD></TR><TR style="mso-yfti-irow: 52"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=6>Kelek
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek 130
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek 5700, 7000
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek 9252
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek 10000
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2892-2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek DK 87
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA with Dubois-Dépraz repeater module
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek DK 94
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA with repeater module; developed for Kelek by Dubois-Dépraz
</TD></TR><TR style="mso-yfti-irow: 59"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=10>Maurice Lacroix
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 20, 45
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>AS 5008 (1973-1977)
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 27, 29
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2836-2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 28, 93
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA/Peseux 7046 (1968-1982)
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 30, 67
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 37
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2824-2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 50
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>FHF/Unitas 6376
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 51
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 57
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 61
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7750 (modified with split-second function)
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 83
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 23 (1916-1974)
</TD></TR><TR style="mso-yfti-irow: 70"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=5>Longines
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>L614.1, L619.1, L620.2, L622
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>L615.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2895/1
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>L633.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2824/2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>L667, L668.2, L674.4, L674.8
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>L987.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 8813
</TD></TR><TR style="mso-yfti-irow: 76"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Minerva
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>24 DT
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7750 (modified with 24-h-dial)
</TD></TR><TR style="mso-yfti-irow: 78"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=3>Franck Muller
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1727
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>AS 1727
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1870
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 1873
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>7000
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7750/7751
</TD></TR><TR style="mso-yfti-irow: 82"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=4>Ulysse Nardin
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>16
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>20, 26
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>UN 53
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 1888
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>UN 70
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Ch. Claret
</TD></TR><TR style="mso-yfti-irow: 87"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=7>Omega
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>651
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA/Peseux 7001
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>725
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2000
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>861, 863
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1108, 1109, 1120
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2892-A2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1138, 1141
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2890-02
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1151, 1152
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7751
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1154
</TD></TR><TR style="mso-yfti-irow: 95"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=7>Oris
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>581
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2688/2671 modified with moon phase and second time zone
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>584
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>586
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2685
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>633, 654
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>641, 644, 649
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>674
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>690
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2836-2 with self-developed quick-set mechanism for the hour hand and second time zone
</TD></TR><TR style="mso-yfti-irow: 103"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=3>Panerai
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>OP III
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7750-P1
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>OP IV
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Zenith "El Primero"
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>OP VII
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Zenith Elite 680
</TD></TR><TR style="mso-yfti-irow: 107"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Perrelet
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>DH95
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2892-A2 with self-developed double rotor
</TD></TR><TR style="mso-yfti-irow: 109"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Piaget
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>9512P
</TD></TR><TR style="mso-yfti-irow: 111"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=5>Robergé
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MMR 3213
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 8815 with double barrel
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MMR 3234
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Dubois-Dépraz module 5100 on base caliber ETA 2892
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MMR 3243
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 8875 with double barrel
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MMR 3298
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Paul Picot 1000 (base Lemania), double barrel
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MMR 5242
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 9640
</TD></TR><TR style="mso-yfti-irow: 117"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Rolex
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>4030
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Zenith 3019 PHC (El Primero 400)
</TD></TR><TR style="mso-yfti-irow: 119"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=3>Universal Genève
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>84
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>88, 98
</TD></TR><TR style="mso-yfti-lastrow: yes; page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>99
</TD></TR></TBODY></TABLE>
<o😛></o😛>Company<o😛></o😛>
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: windowtext 2.25pt ridge; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt" width=208>
Company Caliber Name<o😛></o😛>
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: windowtext 2.25pt ridge; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt" width=269>
Based on Caliber<o😛></o😛>
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=4>Baume & Mercier
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>BM 8395
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>BM 11892
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>BM 13283
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 283, module caliber
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>BM 13750
</TD></TR><TR style="mso-yfti-irow: 6"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=3>Breitling
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Breitling 10, 19, 30, 26, 39, 40
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Breitling Caliber 12
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 1877
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Breitling Caliber 13
</TD></TR><TR style="mso-yfti-irow: 10"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=5>Bvlgari
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MVA 060
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>GP 8293
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MVA 900
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>GP 8290
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MVT 3002 I
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>GP Manufacture 3002
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MVT 9902 TB
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>GP 9902
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MVT R 220 R
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>GP Manufacture 220
</TD></TR><TR style="mso-yfti-irow: 16"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=12>Cartier
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 021
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 21P
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 048
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2893
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 049, 149
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 077
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2671
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 078
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2512
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 096
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 99P
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 191
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Girard-Perregaux GP 3100
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 200, 220
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 205
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 1185
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier 430 C
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Piaget 430P
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier VC 200043
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Piaget 212
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Cartier VC 200049
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Piaget 9P2
</TD></TR><TR style="mso-yfti-irow: 29"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=2>Chronoswiss
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Chronoswiss C.732, C.741, C.741 S,
C.753, C.754, C.755
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 7750
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>C.1722 R
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Minerva 1722
</TD></TR><TR style="mso-yfti-irow: 32"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Corum
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Corum 58
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 70
</TD></TR><TR style="mso-yfti-irow: 34"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=4>Ebel
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Ebel 080
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 8810
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Ebel 124
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Ebel 136
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Zenith El Primero 400
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Ebel 964
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 9.51
</TD></TR><TR style="mso-yfti-irow: 39"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=2>Louis Erard
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ER 48, ER 51
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Peseux 7001
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ER 57, ER 61
</TD></TR><TR style="mso-yfti-irow: 42"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Fortis
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>F 2001
</TD></TR><TR style="mso-yfti-irow: 44"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Gevril
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>BO111, CO111
</TD></TR><TR style="mso-yfti-irow: 46"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=5>IWC
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>IWC C.849
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Jaeger-LeCoultre 849
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>IWC C.884/2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Jaeger-LeCoultre 889
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>IWC C.887/2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Jaeger-LeCoultre 887/2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>IWC C.891/2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Jaeger-LeCoultre 891/2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>IWC C.960
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Jaeger-LeCoultre 960
</TD></TR><TR style="mso-yfti-irow: 52"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=6>Kelek
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek 130
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek 5700, 7000
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek 9252
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek 10000
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2892-2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek DK 87
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA with Dubois-Dépraz repeater module
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>Kelek DK 94
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA with repeater module; developed for Kelek by Dubois-Dépraz
</TD></TR><TR style="mso-yfti-irow: 59"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=10>Maurice Lacroix
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 20, 45
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>AS 5008 (1973-1977)
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 27, 29
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2836-2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 28, 93
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA/Peseux 7046 (1968-1982)
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 30, 67
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7750
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 37
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2824-2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 50
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>FHF/Unitas 6376
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 51
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2892-A2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 57
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2000
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 61
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7750 (modified with split-second function)
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>ML 83
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 23 (1916-1974)
</TD></TR><TR style="mso-yfti-irow: 70"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=5>Longines
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>L614.1, L619.1, L620.2, L622
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>L615.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2895/1
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>L633.5
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2824/2
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>L667, L668.2, L674.4, L674.8
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>L987.2
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 8813
</TD></TR><TR style="mso-yfti-irow: 76"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Minerva
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>24 DT
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7750 (modified with 24-h-dial)
</TD></TR><TR style="mso-yfti-irow: 78"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=3>Franck Muller
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1727
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>AS 1727
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1870
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 1873
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>7000
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7750/7751
</TD></TR><TR style="mso-yfti-irow: 82"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=4>Ulysse Nardin
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>16
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>20, 26
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>UN 53
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 1888
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>UN 70
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Ch. Claret
</TD></TR><TR style="mso-yfti-irow: 87"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=7>Omega
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>651
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA/Peseux 7001
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>725
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>861, 863
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1108, 1109, 1120
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1138, 1141
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2890-02
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1151, 1152
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7751
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>1154
</TD></TR><TR style="mso-yfti-irow: 95"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=7>Oris
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>581
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2688/2671 modified with moon phase and second time zone
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>584
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>586
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2685
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>633, 654
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>641, 644, 649
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>674
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>690
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2836-2 with self-developed quick-set mechanism for the hour hand and second time zone
</TD></TR><TR style="mso-yfti-irow: 103"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=3>Panerai
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>OP III
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Valjoux 7750-P1
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>OP IV
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Zenith "El Primero"
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>OP VII
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Zenith Elite 680
</TD></TR><TR style="mso-yfti-irow: 107"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Perrelet
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>DH95
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>ETA 2892-A2 with self-developed double rotor
</TD></TR><TR style="mso-yfti-irow: 109"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Piaget
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>9512P
</TD></TR><TR style="mso-yfti-irow: 111"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=5>Robergé
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MMR 3213
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 8815 with double barrel
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MMR 3234
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Dubois-Dépraz module 5100 on base caliber ETA 2892
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MMR 3243
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Lemania 8875 with double barrel
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MMR 3298
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Paul Picot 1000 (base Lemania), double barrel
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>MMR 5242
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Frédéric Piguet 9640
</TD></TR><TR style="mso-yfti-irow: 117"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85>Rolex
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>4030
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 201.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=269>Zenith 3019 PHC (El Primero 400)
</TD></TR><TR style="mso-yfti-irow: 119"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 421.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=562 colSpan=3><o😛></o😛>
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 2.25pt ridge; WIDTH: 63.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" vAlign=top width=85 rowSpan=3>Universal Genève
</TD><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>84
</TD></TR><TR style="page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>88, 98
</TD></TR><TR style="mso-yfti-lastrow: yes; page-break-inside: avoid"><TD style="BORDER-RIGHT: windowtext 2.25pt ridge; PADDING-RIGHT: 0cm; BORDER-TOP: #ece9d8; PADDING-LEFT: 0cm; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 155.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 2.25pt ridge; BACKGROUND-COLOR: transparent; mso-border-alt: three-d-emboss windowtext 2.25pt; mso-border-left-alt: three-d-emboss windowtext 2.25pt; mso-border-top-alt: three-d-emboss windowtext 2.25pt" width=208>99
</TD></TR></TBODY></TABLE>
<o😛></o😛>
<o😛></o😛>
<o😛></o😛>
