Gagarin Tourbillon
  • Iniciador del hilo Iniciador del hilo Tim
Tim
Tim
Un fantasma assombroso:
The Gagarin Tourbillon features a 60 second flying orbital tourbillon that rotates counterclockwise around the dial counter in 108 minutes.
An integrated rotating magnifying glass allows appreciation of details on the dial. Looking through the loupe to the dial is reminiscent of looking out of the Vostok space capsule towards the earth.
The mechanical manual winding movement was entirely developed and produced by Bernhard Lederer in Switzerland.
The Gagarin Tourbillon is a limited edition of 50 pieces in platinum.
The Gagarin Tourbillon is a limited edition of 50 pieces in platinum featuring a unique 60 second flying tourbillon orbiting the dial counterclockwise in 108 minutes; hour and minutes; manual winding mechanical movement.
Movement: Mechanical manual winding movement developed and produced by Bernhard Lederer in Switzerland.
Tourbillon cage: Forming the word “VOSTOK”
Dimensions: 38 mm x 11.5 mm
Balance frequency: 28, 800 bph/4 Hz
No. of components: 264
No. of jewels: 35
No. of barrels: 3
Power reserve: 80 hours
Case
Featuring integrated rotating magnifying glass
Case material: Platinum 950
Dimensions: 42 mm x 15 mm (case), 46.5 mm with magnifying glass ring
Water resistant: 30 meters/3 ATM
Sapphire crystals: Sapphire crystal and sapphire crystal display
Dial
Micro-engraved text with highlights of Yuri Gagarin’s flight
Indications: Hours and minutes
Strap & BuckleBlack hand-stitched alligator strap with platinum tang buckle
http://www.thegagarintourbillon.com/en/
Acabo de verlo...Alucinante 8o
Bonito y espectacular. Otra gran obra de arte con la que deleitarnos...
Que pasada, increible lo que hacen
Sinceramente , no me gusta nada.
