custom
Hola compañeros....
Como dice el titulo me gustaría que me ayudarais a elegir entre 3 o 4 modelos que me gustan son estos :
44mm Marina Militare Black Sandwich Dial Swan Neck 6497
- Products Details
BRAND: Marina Militare
MOVEMENT: seagull 3600 (hand winding Asian Swan Neck 6497 movement 17-Jewels)
CASE DIAMETER: 44 mm without crown
THICKNESS: 14.5 mm
DIAL COLOR: Black Sandwich dial with green number
SECONDS HAND: at 9 o'clock
Hand and marks :luminous
CASE MATERIAL: polished 316L stainless steel case case with back and polished bezel
BRACELET: Leather Strap with buckle or Rubber Strap
FRONT GLASS: scratch proof mineral glass
BACK GLASS: Display Caseback
CLASP TYPE : Normal Tang Buckle
44mm Marina Militare Black Sandwich Dial 6497 hand winding watch
MOVEMENT: ST3600 (hand winding 6497 movement 17-Jewels)
THICKNESS: 14.5 mm
BACK GLASS: Display Caseback with detailed engraving
If you want sapphire glass, each watch increases 25USD,
Please click here to increase sapphire glass :
40mm Marina Militare Black Dial Automatic
MOVEMENT: automatic
CASE DIAMETER: 40 mm without crown
THICKNESS: 15 mm
DIAL COLOR: Black dial
CASE MATERIAL: Brushed 316L stainless steel case case with back and polished bezel
BRACELET: Leather Strap with buckle(Strap optional:Black Strap or Brown Strap)
BACK GLASS: Solid Case back with insignia
CLASP TYPE : Deployment Buckle
MOVEMENT: automatic
THICKNESS: 15 mm
Un saludo y gracias de antemano.
- Products Details
THICKNESS: 14.5 mm
THICKNESS: 14.5 mm
MOVEMENT: automatic
THICKNESS: 15 mm
MOVEMENT: automatic
THICKNESS: 15 mm
