Octoberseventyfour
Buenos días!
Ya encontré algo de información sobre estos relojes que EMHO son una preciosidad. Indagando sobre distribuidores descubrí algunos en europa, hice la consulta de precio y disponibilidad pero debo ser muy pobre, incluso virtualmente, por que ni me han contestado
Copio/pego las especificaciones técnicas:
[h=1]Technical Specifications[/h][TABLE="width: 100%"]
[TR]
[TD]FUNCTIONS:[/TD]
[TD]Date, Days, Hours, Minutes, Seconds (360’’)[/TD]
[/TR]
[TR]
[TD]ARCHITECTURE:[/TD]
[TD]Sandwich construction with titanium membrane between movement and fluid-filled indication module.[/TD]
[/TR]
[TR]
[TD]SYSTEM:[/TD]
[TD]Information transmitted from movement to indications by micro-magnetic fields .[/TD]
[/TR]
[TR]
[TD]CASE:[/TD]
[TD]Sapphire crystal and grade 5 titanium[/TD]
[/TR]
[TR]
[TD]DIMENSIONS:[/TD]
[TD]44mm x 15mm[/TD]
[/TR]
[TR]
[TD]CRYSTALS:[/TD]
[TD]Domed sapphire crystals top and bottom with anti-reflective coating on both sides[/TD]
[/TR]
[TR]
[TD]INDICATIONS:[/TD]
[TD]Convex dial and indications (radius: 125mm) in grade 5 titanium with black DLC.
Indications engraved and filled with white, grey and orange Super-LumiNova, glowing green and orange in the dark.[/TD]
[/TR]
[TR]
[TD]MODULE:[/TD]
[TD]Patented system invented and developed by Ressence.
Independent module comprising 28 gears and 57 jewels
Grade 5 titanium plate integrating three eccentric biaxial satellites inclined at 3° and 4,75° with a date ring around the circumference.
Shock absorber system.
The module and indications are completely immersed in fluid.
A thermal valve compensates for expansion/contraction of the fluid[/TD]
[/TR]
[TR]
[TD]MOVEMENT:[/TD]
[TD]Automatic winding movement, 25 jewels
Power reserve 36 hours,
Balance frequency 28.800 A/h
Visible ring-shape winding rotor[/TD]
[/TR]
[TR]
[TD]COMPONANTS:[/TD]
[TD]Total of 407 components.[/TD]
[/TR]
[TR]
[TD]WEIGHT:[/TD]
[TD]80 grams.[/TD]
[/TR]
[/TABLE]
Como concept watch es precioso, y como nuevo desarrollo a mi entender es alta relojería.
Tendríais mas información más allá de la web?
[TR]
[TD]FUNCTIONS:[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]SYSTEM:[/TD]
[/TR]
[TR]
[TD]CASE:[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]CRYSTALS:[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]MODULE:[/TD]
[/TR]
[TR]
[TD]MOVEMENT:[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]WEIGHT:[/TD]
[TD]80 grams.[/TD]
[/TR]
[/TABLE]
. Un saludo.
