Panerai PAM 233 - Luminor 19508 dias GMT
  • Iniciador del hilo Iniciador del hilo cddave
C
cddave
Hola .-
Pongo a la venta mi 233 serie I con indicador "DOT"
pido por el 6500 euros entrega en mano en Barcelona.
Set completo de caja, papeles y etiquetas. La correa tunnel esta sin usar.
cualquier consulta por privado. No cambios.
Gracias
Especificaciones técnicas :
Movement: hand-wound mechanical, Panerai Calibre P.2002/1, completely manufactured by Panerai, 13¾ lignes, 6.6 thick, 21 jewels, 8-day power reserve, 3 spring barrels, Glucydur® balance, 28,800 alternations/hour (4 Hz). KIF Parechoc® anti-shock device.
Functions: hours, minutes, seconds, date, second time zone, 24h indicator, horizontal power reserve indicator, second reset.
Case: diameter 44 mm, brushed steel;
Bezel: polished steel;
Back: see-through sapphire crystal.
Device protecting the crown: (protected as a Trade Mark) brushed steel;gold.
Crystal: sapphire, made from corundum, 2 mm thick. Anti-reflective coating.
Water-resistance: 10 bar (~100 meters).
Strap: calf with Panerai personalised steel large-size buckle buckle.
*Officine Panerai is not the owner of the Trade Mark Glucydur® and KIF Parechoc®
algunas fotos :
