Obris Morgan Pradata
  • Iniciador del hilo Iniciador del hilo juanpam
juanpam
juanpam
[TR]
[/TR]
[TR]
[TD]Marca:
[/TD]
[TD]Obris Morgan[/TD]
[/TR]
[TR]
[TD]Modelo:[/TD]
[TD]Pradata[/TD]
[/TR]
[TR]
[TD]Año de compra:[/TD]
[TD]2014[/TD]
[/TR]
[TR]
[TD]Usado[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Movimiento:[/TD]
[TD]Miyota 9015[/TD]
[/TR]
[TR]
[TD]Caja (medidas):[/TD]
[TD]43mm[/TD]
[/TR]
[TR]
[TD]Cristal:[/TD]
[TD]zafiro de 3.5mm[/TD]
[/TR]
[TR]
[TD]Esfera:[/TD]
[TD]Negra con indices blancos[/TD]
[/TR]
[TR]
[TD]Brazalete:[/TD]
[TD]Acero completo y nato zulu a estrenar[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]¿Estuche? s/n[/TD]
[TD]Si, caja tipo peli[/TD]
[/TR]
[TR]
[TD]¿Documentación? s/n[/TD]
[TD]Si[/TD]
[/TR]
[TR]
[TD]Si[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Precio: (o Cambio)[/TD]
[TD]320€, solo venta[/TD]
[/TR]
[TR]
[TD]¿Envío incluido? s/n[/TD]
[TD]Si, por agencia[/TD]
[/TR]
[TR]
[TD]Forma de envío[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
Hola a todos, por falta de uso, saco a la venta otra edicion limitada, en este caso es el Obris Morgan Pradata en su acabado acero cepillado y dial negro con indices en blanco, aqui sus caracteristicas:
Watch Case : SUS316L Stainless Steel
Bracelet : 4.2mm Thickness 5 links Bracelet
Crown : SUS316L Stainless Steel
Case back : Solid SUS316L Stainless Steel
Movement holder : 316L Stainless Steel
Movement : Automatic Calibre - Miyota 9015
Movement Frequency : 28,800 bph (beats per hour)
Accuracy : +0 to +10 sec/day
Dial : SuperLuminova Lumed (C1)(C3) indices
Hour hand: Skeleton hand fill superluminova lume (C1)(C3)
Minute hand : Skeleton hand fill superluminova lume (C1)(C3)
Second : Skeleton hand fill superluminova lume (C1)
Bezel : 120 Clicks uni-directional bezel
Dimensions : Bezel 44mm diameter, Case Body exclude crown guard 43mm,
Thickness : Bezel 4.5mm, Case 6mm, Back case 2.2mm
Lug width : 22mm
Lug to Lug width : 52.6mm
Crown : 7mm x 4mm
Automatic Helium Escape Velve (Operate at 5 atm pressure inside)
Water Resistance: 30 ATM / 300 meters
Crystal : 3.5mm Thickness Sapphire(Single side anti-reflective coated)
Weight : 236 g (Full linked Barcelet)
Each Package included :
1 Spare screw bar & screw
2 1.4mm heavy duty Blue or Desert Color 5 rings zulu
3 Instruction Manual
4 Warranty Card
Va con toda su dotacion de origen: caja tipo peli, pasador de la caja de repuesto, correa nato a estrenar, documentacion y garantia vigente.
Precio de venta 320€ envio por agencia a mi cargo, no cambios por favor.
