o cambio Zixen Trimix 1000 gmt ( marzo 2011)
  • Iniciador del hilo Iniciador del hilo marcosktm
marcosktm
marcosktm
Hola, vendo o cambio este aparato. Es de marzo de 2011 y está totalmente impecable, ni una marca. Trae correa metálica y caucho. Precio: 950 Euros.
Features:
Trimix professional diver, engineered to handle 100 bar pressure rating. Its 4.5mm thick special sapphire crystal is brilliantly clear designed to perform at extreme conditions. The massive 44mm case is rated at 100 bar. Equipped with an automatic Helium release valve.
Unidirectional rotating bezel with unique filled in luminous markers. Supplied with a rubber strap & stainless steel bracelet, or 4mm stainless steel heavy duty #mesh bracelet.
Details:
Case: Double O-ring, brushed solid stainless steel (316L), 44mm rated @ 100bar excluding crown. 16 mm in height. Screwdown crown with double O-ring design for superior water resistant capability, rated to 3300 feet.
Crystal: Anti-reflective, 4.5 mm domed sapphire.
Bezel: Unidirectional with luminous markers and numerals.
Movement: Swiss made modified ETA 2836 GMT self-winding, hacking second function, 42 hr power reserve.
Bracelet: Integrated stainless steel with butterfly clasp, or 4mm heavy duty mesh bracelet, 24mm and natural rubber professional grade diving strap.
Esta foto no es mia, es de Demo, pero es buenísima.
Aquí hay un post con alguna foto de cuando lo compré. El reloj lo tengo en españa.
https://relojes-especiales.com/threads/mi-zixen.166937/?highlight=zixen
Gracias.
