Nuevo Panerai 389
  • Iniciador del hilo Iniciador del hilo NachoM
N
NachoM
fuente: p.com
LUMINOR SUBMERSIBLE 1950 AMAGNETIC 3 DAYS AUTOMATIC TITANIO - 47MM
The creative energy of Officine Panerais Workshop of Ideas is demonstrated in the Luminor
Submersible 1950 Amagnetic 3 Days Automatic Titanio, the new model which is a
novel synthesis of the strict respect for traditional values and authenticity of the Panerai brand,
and the continuous search for technically advanced solutions.
Remarkable resistance to magnetic fields
For Panerai, innovation is above all about functionality, and in the Luminor Submersible 1950
Amagnetic 3 Days Automatic Titanio it is seen in its special case construction which ensures a
remarkable degree of resistance to magnetic fields: 40,000 A/m (ampere per metre), a limit more
than eight times greater than the value specified by the international standards of the Normes
de lIndustrie Horlogère Suisse (NIHS 90-10). Such a high limit is achieved by the use of a special
internal case made of soft iron of the highest purity, which encloses and isolates the movement,
forming a Faraday cage that diverts the flow of magnetic fields. The soft iron case is immediately
beneath the dial, which is made of the same material.
This case structure is useful not only in extreme environmental situations but also in daily life,
in that watches are often exposed to magnetic fields generated by electric charges and
currents emanating from objects in common use, such as household appliances, computers
2 and cell phones. Such magnetic fields can noticeably alter the rate of the watch and even stop
the movement: a possibility that is virtually non-existent in the new Luminor Submersible 1950
New ceramic and titanium bezel
The soft iron internal case of the Luminor Submersible 1950 Amagnetic 3 Days Automatic Titanio
is contained within a classic Luminor Submersible case of brushed titanium, fitted with the lever
bridge which locks the winding crown and thus helps in achieving water-resistance to a depth
of 300 metres. The design of the watch includes a feature which is completely new in Panerai
watches: applied to the rotating titanium bezel, inspired by that of the models made by Panerai
for the Egyptian Navy in the 1950s, is a disc of opaque black ceramic, on which the linear and
dot-shaped titanium markers are fixed. The bezel rotates only in a clockwise direction, to prevent
accidental movement interfering with the measurement of the time of the dive.
Movement:
Automatic mechanical, Panerai P.9000 calibre, executed entirely by Panerai, 13¾ lignes, 7.9 mm thick, 28 jewels, Glucydur® balance, 28,800 alternations/hour.
Incabloc® anti-shock device. Power reserve 3 days, two barrels. 197 components.
Functions:
Hours, minutes, small seconds, date, calculation of immersion time.
Case:
Diameter 47 mm, brushed titanium.
Bezel:
Anti-clockwise unidirectional rotating bezel in ceramic and brushed titanium with polished edges, graduated scale for calculating the time of immersion and ratchet click at minute intervals.
Back:
Screw, titanium.
Device protecting the crown:
(protected as a trademark) Brushed titanium.
Dial:
Black with applied luminous hour markers.
Date at 3 oclock, seconds at 9 oclock.
Crystal: Sapphire, formed of corundum, 3.2 mm thick. Anti-reflective coating.
Water- resistance:
30 bar (~ 300 metres).
Strap:
PANERAI personalised rubber strap and large-size brushed titanium buckle. Supplied with a second interchangeable strap, a tool to change the strap and a steel screwdriver.
Available this October, priced at 8900 Euro
Muy guapo Nacho!!
Regular????
SI...parece que si. Regular
pues la verdad no se si me gusta o no ....
A falta de verlo en vivo, me gusta mucho, lastima (por mi muñeca) de 47mm... :)
Me gustan todos los Panerai, éste no iba a ser menos.
Ostras que guapo!!!
Me gusta muchísimo este Submersible!
Sent from my iPhone using Forum Runner
No me gusta, ese bisel negro es "infiel" a Panerai. Parece un Navy Seals.
Siiii! Me gusta muchísimo éste "Navy Seals"! 🙂
Es muy tool watch con la caja antimagnética sin fondo visto, el titanio mate y el bisel cerámico. Al mismo tiempo queda noble con los indices enmarcados!
Ya me veo con él .... ;-)
Este SUB llama mas mi atención
Madre mía que guapo esta ese me lo quedaba yo con los ojos cerrados
Me parece espectacular... 8o
mmm... pues todavía no he decidido si me gusta o no..... :pardon:
Tiene demasiado aire a los biseles de los Navy Seals.... y por eso parece menos "Panerai" que otros modelos.... vamos que espero que la luminova no sea también de color azul... ::bash::
En fin... la suerte es que como es de 47" me da igual que me guste que que no....:D
Supongo que me acostumbraré, pero mi primera impresión estética es... negativa :pardon:
(Sólo mi opinión basada en gustos muy personales): No me parece un Panerai, y la cerámica negra hace que los índices resalten demasiado, emborronando y haciendo demasiado llena de cosas la 'cara' del reloj. Supongo que por eso no me parece un Panerai.
Con la de divers chulos que tiene mi querida Panerai, ahora van y se suman a la moda de la cerámica :yuck::. Menos mal que mis PAM ya llenan todas mis inquietudes de paneristi, pero aún así, me encanta cuando sacan cosas como el 425, que me hace buscar fotos y hasta querer probármelo. Pues no va a ser así con este 389...
Me parece muy chulo, pero los 47mm no tanto...:nea:
Lo veo extraño, no termina de hacerme el peso, aunque he de decir que los divers de Pam no me gustaba ninguno, y este no me disgusta. No sé, y esos 47...
Habrá que verlo en vivo...
Es chulisimo. Un reloj grande en todos los sentidos.
Casi kilo y medio :) , tiene su que pero más valïa que lo hicieran en bronce :) , saludos
Me gusta, pero no lo acabo de ver con esa correa.
Aunque eso tiene fácil solución ;-)
Gracias por presentarlo.
He leido alguna vez: "no me gustan los Pam, me parecen todos iguales" ... seguramente los de Panerai lo han leido también y han querido ampliar mercado :D
A mí me gusta, al menos en la foto, mi muñeca no me permite esos tamaños.
+1 Opino lo mismo, creo que se sale de la linea más fiel de Panerai, bonito lo es pero no es tan tan Panerai, los "acuáticos" son más contundentes con más metal visto.
En fin todo bajo mi humilde opinión.
Saludos a todos.
Es una extraña sensación ver un Pam así...tiene muy buen aspecto, aunque se sale de lo normal.
hay que verlo en vivo :)
Gracias por presentarlo.:ok::
El reloj me gusta, es muy bonito, lo unico malo es que no parece un Panerai, y eso ya no me gusta tanto.
Uff.f...me encanta. Ayer mismo estuve viendo fotos de un 303 que ultimamente me gustaba, pero lo veía demasiado "parecido"....
Creo que con el bisel oscuro como la esfera parecerá mas grande.
Me gusta la indicación en la esfera y los índices embutidos del bisel....
Tengo ganas de verlo.
Y cual es 303?????8o8o
A mi me gusta, pero está lejos de lo que busco en un pam!!
Mucha leyenda en el dial, sobraba EMHO, el automatic de la esfera.
Y si, tiene cierto aire Navy Seals!!!!
