Armis Super Oyster 22mm para Seiko SKX009, SKX007, etc...
  • Iniciador del hilo Iniciador del hilo Scuba dude
Scuba dude
Scuba dude
Around the World
El armis que estabas buscando.. la oferta que no puedes dejar pasar.
A Michael from Toronto le queda así:
Por 53€ lo compras en strap-code. Por 55€ te lo pongo en casa por agencia 24H y te meto en el paquete una Bonetto Cinturini Naranja a estrenar de 22mm (Buckle no original) y una herramienta para cambio de pasadores. Esta de reestreno. Micro-pelos en el cierre (si, si, tu también se los haces :clap:). 2 puestas contadas.
[TABLE="width: 98%"]
[TR]
[TD="class: main"][TABLE="width: 100%"]
[TR]
[TD="class: main, align: left"]Seiko Diver SKX007, SKX009 & SKX011 replacement band. Heavy duty Super Oyster solid 316L stainless steel bracelet design for Seiko Diver SKX007, SKX009 & SKX011 models or other 22mm lug Seiko diver or sport cases with the same curvature as the above models. Generic 2.5mm Diameter stainless steel spring bars included.
Brand Name : Super Oyster
Lug width : 22mm
Buckle size : 18mm
Buckle Include : Yes
Buckle type / Finish : 316L Stainless Steel Double FlipLock Diver's Clasp with Push Button
Overall Length : 195mm
Thickness : 3.4mm
Spring bar hole dia. : 2.5mm (included)
Design to fit : SEIKO SCUBA DIVER'S SKX007 / SKX009 / SKX011 replacement watch band
Material : 316L Stainless Steel, all solid links include end links
Color / Finish : Brushed
Max. length : 175mm
Min.length : 110mm
Net Weight : 96g
Lug end style : Curve End
Adjustment type : Screw fixed Link + 3 micro hole type adjustment
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]
[/TD]
[/TR]
[TR]
[TD="class: main"][/TD]
[/TR]
[/TABLE]
Gracias!!
Vendido.
