Xocaso5
MOVEMENT: 2813 Automatic (self-winding) movement
CASE DIAMETER: 40 mm without crown
THICKNESS: 13 mm
DIAL COLOR: Blackdial
CASE MATERIAL: brushed 316L stainless steel case with brushed back BRACELET: stainless steel
FRONT GLASS: scratch proof mineral glass
BACK GLASS: Solid Case back with insignia
65$
automatic watch movement ( no batter required)
Brand new
screw in and out handset luminous hour makrers
solid satinless steel case, band.
date window is for quick set
40 in diameter
the strap is 20cm in length. If it's long for your wrist, you could remove the links at any time.
no paper and box
1 year warranty
58'50$
