Josemaval
De la casa
Limitado a tan sólo 12 unidades que sólo venderán en 4 joyerías-relojerias, por un precio de 135.000 Usd.
Copio y pego las especificaciones: Info: A blog to read:
Technical Specifications UR-110 ZrN Torpedo
An Édition Spéciale of just 12 pieces available exclusively from Chronopassion (Paris), Marcus (London), The Hour Glass (Singapore) and Westime (Los Angeles).
Case
Grade 5 titanium with bezel in 316L sandblasted stainless steel treated with *Zirconium Nitride
Dimensions: 47mm x 51mm x 16mm
Two-position winding crown with cover
Water resistance: Pressure tested to 3 ATM
Movement
Calibre: UR 9.01 self-winding
Balance: Monometallic
Jewels: 46
Frequency: 28,800v/h, 4Hz
Balance spring: Flat
Power: Single mainspring barrel
Power reserve: 39 hours
Winding system: Unidirectional winding rotor coupled to twin turbines
Finish: Circular graining and diamond polishing
Chamfered and polished screw heads
Indications
Revolving satellite complication with rotating hour/minute modules mounted on planetary gears
Control Board: Day/Night indicator; “Oil Change” indicator and running seconds
*Please note that ZrN (Zirconium Nitride) is an industrial treatment that can result in variations in and the color/hue on the bezel and between individual models.
Fotos:
Case
Movement
Jewels: 46
Indications
Fotos:
Espero algun dia poder comprarme uno aunque lo veo bastante dificil... Pero en definitiva un reloj bellisimo!
