sinn ux ezm
  • Iniciador del hilo Iniciador del hilo nosferatux
nosferatux
nosferatux
Vendo Sinn Ux EZM Hydro
Características detalladas:
Temperature-stabilized chronometer quartz movement
ETA 955.652
7 bearing jewels
Seconds stop function
Shock resistant as per DIN 8308
Anti-magnetic as per DIN 8309
Case
Case made of German submarine steel, bead-blasted
Sapphire crystal glass in front, anti-reflective on both sides
Case back screw-fastened
Water-resistant as per DIN 8310
Pressure resistance of the movement up to 5,000 m diving depth (= 500 bar) and of the case up to 12,000 m diving depth (1,200 bar), certified by Germanischer Lloyd Hamburg
According to the technical demands for the diving norm DIN 8306
Tested based on European diving equipment standards EN 250 / EN14143 and certified by Germanischer Lloyd Hamburg
Low pressure resistant
Functions
Hours, minutes, seconds
Date display
Diver’s bezel with minute ratcheting and luminous key mark
SINN Technologies
HYDRO Technology for perfect readability even under water and freedom from reflection at any angle and completely free from fogging
Bezel with TEGIMENT Technology, therefore especially scratch-resistant
Captive bezel
Temperature resistance technology, therefore functionally reliable
at temperatures from -45 °C up to +60°C
Crown with D3-System
Dimensions and Weight
Case diameter: 44 mm
Band lug width: 22 mm
Case thickness: 13.3 mm
Weight without strap: 105 gramme
Dial and Hands
Matte black dial
Indices coated with luminescent colour
Hour, minute and second hand coated with luminescent color
Warranty 3 years
Está en perfecto estado pese a ser del año 2006.
Se entrega con caja, garantía, certificado COSC, manual y brazalete de caucho cortado para muñeca de 17,5 mm
La visibilidad de la esfera en cualquier posición es perfecta debido a su tratamiento hydro. Literalmente parece que no tiene cristal.
Toda una bestia de las profundidades (certificado hasta 12.000 metros) por solo 750€ envió incluido.
No me interesan cambios.
La correa de Jacobo que tiene en las fotografías no esta incluida
    5,5 KB · Visitas: 44
    5,5 KB · Visitas: 33
rebajado a 600€
