Sinn U2 Solebox
  • Iniciador del hilo Iniciador del hilo dreft
D
dreft
Pictures of the final watch will follow…
The diving watch U2 is a professional mission timer which uses genuine German submarine steel, a material with extreme seawater resistance and the highest level of anti-magnetic properties. In the movement itself, functional reliability between -45 °C and +80 °C is ensured by the SINN special oil 66-228. And that´s not all: with the diver´s bezel tempered to 1500 Vickers, this diving watch is well-equipped to measure the duration of a dive accurately.
Fogging of the dial poses a safety risk when diving. To prevent this, we use seals made of Viton®. This material, with its extreme chemical resistance and only a quarter of the gas permeability of conventional seals, prevents moisture from diffusing into the diving watch. The slightly domed, 4.2 mm thick scratch-proof anti-reflective sapphire crystal glass with a hardness von 1800 HV withstands even the highest pressures. The case is filled with a protective gas, while three drying capsules keep the interior dry.
MovementCaliber:ETA 2893-2
Movement winding:Automatic
Bearing jewels:21
Alternations:28.800 /Std.
CaseCase material:German submarine steel Black hard coating
Crystal:Sapphire crystal glass, with anti-reflective coati
Case back:Solid
Waterproof:yes
Pressure resistance:200 bar
Diameter of case:44,0 mm
Watch thickness:15,5 mm
Weight:114 g
•Tested based on European diving equipment standards and certified by Germanischer Lloyd Hamburg
•Pressure-resistant to 200 bar (corresponds to approximately 2,000 m diving depth), certified by Germanischer Lloyd Hamburg
•Case made of German submarine steel
•Completely seawater-resistant
•All case components, clasp and bracelet with TEGIMENT technology and black hard coating
•Captive diver´s bezel Sapphire crystal glass with state-of-the-art anti-reflective coating technology
•Ar dehumidifying technology to ensure enhanced freedom from fogging
•Functionally reliable at temperatures between -45 °C and +80 °C thanks to SINN Special Oil 66-228
•Second time zone on a 24-hour basis
•Mission timer design for optimal readability
Q es una edicion limitada ¿?
Parece semi-stealth...
Patricia, como se que leerás esto, aprovecho para decirte que borres tu inbox, que lo tienes lleno...
Tá guay, PVD, rollito Phantom con un puntito orange...:drool:
en la Sinn store no lo veo...esperamos al Lunes a ver que nos dice Super Patricia :D
Salu2 :ok::
Hola, demasiado oscuro para mi gusto, me quedo con el acabado normal.
Muy, muy guapo. Me gustan en general los relojes tipo all black o semi all black en este caso :)
No acabo de ver la gracia de estos All blacks...prefiero el modelo normal.Gracias por mostrarlo
Salu2 :ok::
No tengo info al respecto, por lo que seguramente será una edición de encargo...
A mi me encanta pero claro, habrá que ver el precio... :)
Me encanta el "lado oscuro" de Sinn...A ver si lo hacen con mas modelos!
ufffffff cómo me pone tan oscuro y con ese toque naranja en el bisel:drool:
A mí me sigue encantando el U2 de toda la vida, estos negritos no me terminan de convencer...
que pena que no sea un nuevo modelo de serie,
este all black con toques naranja me encanta :yes:
