Precista PRS18Q
  • Iniciador del hilo Iniciador del hilo retina
retina
retina
Vendo prs18q, reedición del reloj militar de Precista, versión cuarzo, movimiento Ronda 715Li con batería de 10 años, no es necesario abrirlo en una década lo que garantiza su estanqueidad por largo tiempo, estas son las características copiadas de la web de Timefactor:
[TABLE="width: 80%"]
[TR="bgcolor: #ffffff"]
[TD="width: 38%"] MODEL[/TD]
[TD="width: 62%, bgcolor: #ffffff"] PRECISTA 93 – PRS-18 QUARTZ
[/TD]
[/TR]
[TR="bgcolor: #ffffcc"]
[TD="width: 38%"] CASE[/TD]
[TD="width: 62%"] [/TD]
[/TR]
[TD="width: 38%"] Material[/TD]
[TD="width: 62%, bgcolor: #ffffcc"] 316L stainless steel,completely bead blasted[/TD]
[/TR]
[TD="width: 38%"] Diameter[/TD]
[TD="width: 62%"] Bezel 39mm, 43.5mm across including crown[/TD]
[/TR]
[TD="width: 38%"] Lug to lug height[/TD]
[TD="width: 62%"] 47.5mm[/TD]
[/TR]
[TD="width: 38%"] Thickness[/TD]
[TD="width: 62%, bgcolor: #ffffcc"] 12.5mm[/TD]
[/TR]
[TD="width: 38%"] Lug spacing[/TD]
[TD="width: 62%, bgcolor: #ffffcc"] 20mm[/TD]
[/TR]
[TD="width: 38%"] Anti-magnetic[/TD]
[TD="width: 62%"] 4800 A/m[/TD]
[/TR]
[TD="width: 38%"] Water resistance[/TD]
[TD="width: 62%"] 300 metres, double Viton 'O' ring seals on case back[/TD]
[/TR]
[TD="width: 38%"] Weight[/TD]
[TD="width: 62%"] 80 grammes without strap[/TD]
[/TR]
[TD="width: 38%"] Features[/TD]
[TD="width: 62%"] Screw down crown, 120 click unidirectional bezel[/TD]
[/TR]
[TD="width: 38%"] DIAL[/TD]
[/TR]
[TD="width: 38%"] Colour[/TD]
[TD="width: 62%"] Semi-matte black[/TD]
[/TR]
[TD="width: 38%"] Luminous[/TD]
[TD="width: 62%"] Hour markers & bezel triangle Super Luminova C3[/TD]
[/TR]
[TD="width: 38%"] Day/Date[/TD]
[TD="width: 62%"] None[/TD]
[/TR]
[TD="width: 38%"] HANDS[/TD]
[/TR]
[TD="width: 38%"] Style[/TD]
[TD="width: 62%"] Plain skeleton hands, luminous filled[/TD]
[/TR]
[TD="width: 62%"] Super Luminova C3[/TD]
[/TR]
[TD="width: 38%"] CRYSTAL[/TD]
[TD="width: 62%"] 3mm thick sapphire, anti-reflective coating underside[/TD]
[/TR]
[TD="width: 38%"] MOVEMENT[/TD]
[TD="width: 62%, bgcolor: #ffffcc"] Ronda 715Li quartz, 5 jewels with 10 year battery life[/TD]
[/TR]
[TD="width: 38%"] BATTERY[/TD]
[TD="width: 62%"] CR2016 Lithium [/TD]
[/TR]
[TD="width: 38%"] STRAP[/TD]
[TD="width: 62%"] NATO of choice[/TD]
[/TR]
[/TABLE]
El estado es impecable, solo me lo he puesto un par de días, viene con su estuche, la garantía y el resto de documentación, será del primero que me confirme que se lo queda por 185€ envío certificado incluido, no deseo cambiarlo.
Gracias por mirar, y ahora las fotos:
Las señales de la trasera con del plástico de protección que todavía conserva.
