M
Miguel Margolis
Quasi-forer@
Big Bang King Porto Cervo
Among its 2007 novelties, Hublot has launched the largest watch – 48 mm in diameter – in its collection.
A Big Bang of ideal proportions suited to slender as well as larger wrists ! The red gold and white ceramic Porto Cervo model is a good example of this, all the more so as its light and luminous colour is also particularly appreciated by women.
Sporty, distinctive, elegant and … visible. The features of the Big Bang are enhanced by the red gold numerals inserted in the unidirectional rotating bezel. The gold was cast in recesses hollowed out of the ceramic using an innovative process.
Even if its look clearly asserts its vocation as a diving watch, the Big Bang King is suitable for all your outings, not only for the underwater kind ! In this giant timekeeper which matches fine wrists perfectly, we instantly recognise Hublot’s signature, not only in the fusion of materials but also in its style, which is at once sporty and refined.
“BIG BANG KING PORTO CERVO”
TECHNICAL DATA SHEET
Case: “Big Bang” diameter 48 mm in red gold
Bezel: Unidirectional rotating bezel in white ceramic, with red gold numerals cast in the ceramic
Crystal: Sapphire crystal with interior anti-reflection treatment
Lateral Inserts: White composite resin
Back: Solid back in red gold, with BIG BANG KING engraved seal
Crown: Red gold with natural white rubber insert
Screws: Red gold
Water-resistance: 300 m or 30 ATM
Dial: Matte white with appliqué index markers and white luminescent feature, dialtrain and black numerals
Hands: Sand-blasted, faceted, with white luminescent feature, red seconds hands with triangle and white luminescent feature, H-shaped counterpoise
Movement: Mechanical with automatic winding, Hublot HUB21 calibre
No of components: 180
Rubies: 23
Bridges: Polished, satin-finish with chamfered edges
Screws: Polished steel
Calendar: Rectangular aperture at 3 o’clock
Oscillating Weight: Tungsten carbide with dimpled surface coated with black PVD
Bottom plate: Sand-blasted rhodium plated
Barrel: With reinforced spring
Escapement: Glucydur balance spring
Power Reserve: 42 hours
Strap: Adjustable smooth natural white rubber with Hublot logo
Clasp: Red gold cover with steel and black PVD deployant clasp
