Este Dievas no está nada mal...
mandrake
mandrake
Master of Fridays
Verdad? Y por unos 300$ creo, eso sí, cuarzo si no me equivoco, aunque eso puede ser una buena cosa para un reloj de trote.....
No esta mal, no, es pintón, como suele decirse ahora...
saludos
Está guapo. Puedes porner las características? pliz
En ingles, sorry:
The Dievas Divergraph Blue Professional is the latest addition to the Dievas range. The Divergraph is designed with usability and easy time reading in mind.
The Divergraph Blue Professional's robust three-piece case with flat sapphire top crystal is microblasted and then PVDed for a smooth finish. The smooth 120 clicks uni directional black PVD stainless steel bezel has a ceramic bezel insert set in it. Ceramic is well known for its scratch resistance and durability. The ceraemic bezel insert is done in a never seen before matt finished. This finishing is very time consuming. The Dievas signed screwdown back is essential to maintain its water resistance. The large black PVD Dievas signed screwdown crown is hidden in a uniquely designed crown guard that hides the crown so it does not tug onto anything accidentally. When fully secured, the watch is water resistant up to 200m/660ft.
Colors of the Tritium lights:
- 11 blue tritium tubes / above the the numbers 1-11
- 1 orange tritium tubes / above the the numbers 12
- 3 green tritium tubes on the hour/min/sec hands
All illumination Made in Switzerland by MB Microtec
Mas info
NO me había dado cuenta pero dice que tiene un bisel...cerámico!!!!8o :huh:
Ya solo le falta que lo saquen tambien el rojo y azul....:D :-P
Pues sí que está chulo. Lástima lo de la maquinaria de cuarzo...
