Audi Tachoscope®
  • Iniciador del hilo Iniciador del hilo Tim
Tim
Tim
Tradition and innovation –the Audi centennial watch
Ingolstadt – 100 years of Audi. An exceptional anniversary is being celebrated with an exceptional timekeeper – the Tachoscope, the new Audi centennial watch. It embodies the incomparable spirit of the brand: tradition and innovation, design and precision, sophistication and perfection. A masterpiece of watchmakers’ artistry, this push-piece chronograph with tachometer function has a manufacture caliber and a unique design.
“The Tachoscope is a tribute to 100 years of Audi,” explains Rupert Stadler, Chairman of the Board of Management of AUDI AG. “This timekeeper is a masterpiece of the watchmaker’s craft, a product of passion for mechanical precision. And, it symbolizes the strong roots of our powerful brand.” Audi Design was responsible for styling this exclusive timekeeper, in collaboration with Chronoswiss, its Munich-based development and production partner. Like Audi, Chronoswiss is dedicated to precision and the utmost quality.
DATA
Model: Tachoscope
Automatic wristwatch chronograph with regulator dial face and tachometer, with integral push-piece
Reference: CHA 1521 W and CHA 1520
Display: Hours, minutes, second, chrono-center seconds, tachymeter scale
Housing: Solid 26-part housing, special Audi Design crown with integral push-piece (monopulsante) with replaceable seal system, exclusive design reserved for Chronoswiss, crown set in the solid housing material, diameter 42.80 mm, height: 11.80 mm; screwed, polished bezel with beveled edges and anti-reflective sapphire glass on one side, screwed strap holding bridges with the patented Autobloc system and special
screws (Audi Design), water resistant up to 3 atm, incl. at the setting mechanism; mid-section with horns and brushed finish; upper housing section, push-piece, mid-section surface and beveled edge all polished to a high gloss.
Movement: Manufacture caliber C. 125 (enlarged rotor with dia. 28.00 mm and ring with pearled finish around the movement), automatic winding mechanism, dia. 28,00 mm (11 ¾“), 30 jewels, Incabloc shock rotection, 35-hour power reserve, 3 Hz., 21,600 A/h (oscillations), ratchet mechanism (installed on the dial face side) with kinetic operation, central chrono wheel mounted on ball bearings (for the first time in chronograph design), skeletonized rotor designed by Audi, individually numbered and engraved with the years 909 - 2009 and the four Audi rings logo.
Dial: Dial with enameled face and printed Arabic numerals (special Audi font); timer, hours and minutes recessed, Tachymeter scale with 1/6 second increments (360 graduations), blued steel hands, shape: “Type C”.
Limited edition: Total series of 100 timepieces; 65 in white gold and 35 in platinum.
Delivery scope: The Tachoscope is delivered in a box with a black piano finish. Included are also a watchmaker’s loupe and a special screwdriver for changing the watchband.
Precioso reloj, cuando salió quise ir a por uno, pero era muuuuuuy difícil. Me parece un gran acierto. Feliz Navidad.
I dont like car brands that manufacture watches. The watch is very nice, but isn't for me.
Regards.
No es feo... pero audi lo que tiene que hacer es coches...
Regards.
La marca del reloj es CHRONOSWISS, de la misma manera que PANERAI hace reojes para Ferrari
Es la única dedicatoria reljera automovilítisca que me gusta. Es realmente precioso...
Este ha de ser baratito eh? :whist::
Sí que es muy bonito, aunque más bien yo lo llamaría por su nombre de pila (además del apellido): CHRONOSWISS Audi Tachoscope®...
que precio tiene? a ver si vale mas el reloj que el coche:whist::
Price range: €14,900 to €24,900
Chronoswiss Tachoscope Audi Centennial edition
The German car manufacturer Audi, which is busy celebrating the 100th anniversary of the marque, has recently partnered with the German watchmaker to present a branded version of the last year’s Chronoswiss Tachoscope regulateur chronograph watch. Just like all Audi’s (except, perhaps, the gorgeous R8 sports car) the restyled watch looks, well, just like an overpriced watch.
While the original Chronoswiss Chronoscope Ref. CH1523 with its silvered dial, blued Poire hands and vintage fonts, looked like homage to early chronograph watches, the Chronoswiss Tachoscope Audi Centennial edition edition looks like just another modern watch that you can find in abundance at any boutique in Geneva, Moscow or Dubai.
Yes, the watch has retained its basic regulator-style layout with centrally positioned minute hand and its vertically aligned hour and seconds sub-dials are still located at 12 o’clock and 6 o’clock respectively.
And its only chronograph counter is still operated with a single pusher protruding through the winding crown.
However, the new hands and numerals look just too plain and simple.
Although said to be inspired by instruments of the 1930s Auto Union race cars, in reality they make this, err, product look more like a sophisticated (and hard to read!) pressure gauge, rather than an exquisite timekeeper that it initially was.
Like the original Chronoscope CH1523, the new special edition model is powered by the Chronoswiss Caliber 125 automatic chronograph movement.
Based on Enicar 165 caliber from the 1960s (the German brand acquired a bunch of them in the early 1990s,) the movement has its column-wheel chronograph switching mechanism mounted directly beneath the dial: homage to vintage chronographs from the XIX century.
By the way, do you want to know how a real vintage-inspired timekeeper must look like?
Check the
. That one does look like living classics in my humble opinion.
And they charge €14,900 and €24,900 for the white-gold and platinum versions of this. Well, somebody will even buy it, I suppose.
The original Chronoswiss Chronoscope watch:
Chronoswiss Tachoscope Audi Centennial edition watch’s specification :
Movement: Caliber C.125 based on the Enicar 165 movement
Complications: Chronograph
Power reserve: 35 hours
Case material: white-gold or platinum, transparent caseback
Case dimensions: 38 mm
Case height: N/A
Dial: White
Water resistance: N/A
Strap: Black alligator strap with a folding clasp
Crystal: Sapphire
Aunque me parece muy bien el concepto, por esa pasta encuentras "Ferraris"= AP, JLC, VC, Langes...
Solo comentar que en este caso, Audi, pone en manos de una gran marca su reloj tributo.
Me gustan más los Mercedes :o)
