robalon
Reloj homenaje al earlybird usado por los pilotos ameriacanos en la guerra del vietnam, en este caso vendo el no date , el metodo cabanillas of course, 475 euros , los datos tecnicos
42mm at the bezel, 13.5mm thick, and 22mm lug width
Dial: Will use C3 Superluminova on all the markers, hands and bezel dot. Unlike the original Early Bird, the Arabic numerals on the dial will not glow. There is a date display (white on black) at the lower right corner (0900). This is unobtrusive enough to please both those who need a date and those who like the clean look of the original date-free dial.
Case: Screw down crown and water rated to 30 ATM
Crystal: Flat sapphire with AR (antireflective) coating on the underside only, no “Cyclops” magnifier.
Bracelet: Oyster style bracelet attached using spring bars and using screw pins in the links. The clasp is flip-lock style. Does have diver's extension (allows for use over a wetsuit but does somewhat limit the quick adjustment springbar holes on the clasp).
Bezel: The bezel in unidirectional in ratcheting clicks. It may be possible for the owner to remove the bezel and then remove the one-way spring, thus enabling a bidirectional friction bezel as on the original Early Bird. This would be up to the owner’s discretion. I will look at mine when it arrives to study this, and post updates for you.
Movement: Swiss ETA 2893..Elabore grade
Box: AirNautic leatherette box with polishing cloth and warranty card
[/URL
y una review en youtube
