smartinez
HUAWEY P8 2016 COLOR PLATA A ESTRENAR
EN LA CAJA SIN ABRIR
http://www.huaweispain.com/smartphones/huawei-p8/
PRECIO: 155€ envio certificado incluido
Especificaciones
[TABLE="class: spectable, width: 1100"]
[TR]
[TH]Modelo[/TH]
[TD]Huawei P8[/TD]
[/TR]
[TR]
[TH]Sistema operativo[/TH]
[TD]Android™ 5.0[/TD]
[/TR]
[TR]
[TH]Banda[/TH]
[TD]TDD LTE: B38/B39/B40/B41 (2555MHz~2655MHz) // FDD LTE:B1/B3/B4/B7 // UMTS: 850/900/1700/1900/2100MHz(B8/B5/B4/B2/B1) // GSM :850/900/1800/1900MHz[/TD]
[/TR]
[TR]
[TH]Dimensiones[/TH]
[TD]144.9x72.1x6.4mm[/TD]
[/TR]
[TR]
[TH]Pantalla[/TH]
[TD]5.2" FHD, 1080p (1920 x 1080), 424ppi 16M colores[/TD]
[/TR]
[TR]
[TH]Batería[/TH]
[TD]2680mAh[/TD]
[/TR]
[TR]
[TH]Memoria interna[/TH]
[TD]RAM: 3 GB; ROM: 16 GB[/TD]
[/TR]
[TR]
[TH]Conectividad[/TH]
[TD]Wi-Fi 2.4GHz b/g/n with Wi-Fi Direct support // BT 4.1+LE // MicroUSB (Alta velocidad USB)[/TD]
[/TR]
[TR]
[TH]Cámara[/TH]
[TD]Cámara principal de 13 MP, OIS, sensor RBGW, Procesador de Señal de Imagen DSLR-level, 1080p video grabación/1080p video playback; F2.0; Flash color temperature dual. 8 Mega píxeles cámara frontal[/TD]
[/TR]
[TR]
[TH]Peso[/TH]
[TD]144g[/TD]
[/TR]
[TR]
[TH]Procesador[/TH]
[TD]Hisilicon Kirin 930, 8-core 64bit, 2.0GHz[/TD]
[/TR]
[TR]
[TH]Color[/TH]
[TD]Champagne místico / Gris Titáneo[/TD]
[/TR]
[TR]
[TH]Otros[/TH]
[TD]GPS/A-GPS/Glonass/BDS(BeiDou Navigation Satellite System)
G-Sensor, Sensor Giroscopio, Sensor de luz ambiente, Sensor de proximidad, Brújula, Acelerómetro
Audio: MP3、MIDI、AMR-NB、AMR-WB、AAC、AAC+、eAAC+、PCM、WMA Vídeo: H.263、H.264、MPEG-4、MOV、ASF、RM、RMVB Imagen: PNG、GIF、JPEG、BMP、WEBP、WBMP 3.5mm Audio Jack
Vídeo Codec: MPEG-4, H.264, H.263, VP8, RV7-10, Xvid, WMV9 Vídeo File Format: *.3gp, *.mp4, *.m4a, *.rm, *.rmvb, *.wmv Codec de imagen: PNG, GIF (solo estático), JPEG, BMP Formato de archive de imagen : *.png, *.gif (Static only), *.jpeg, *.bmp[/TD]
[/TR]
[/TABLE]
Especificaciones
[TR]
[TH]Modelo[/TH]
[TD]Huawei P8[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TH]Banda[/TH]
[/TR]
[TR]
[/TR]
[TR]
[TH]Pantalla[/TH]
[/TR]
[TR]
[TH]Batería[/TH]
[TD]2680mAh[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TH]Cámara[/TH]
[/TR]
[TR]
[TH]Peso[/TH]
[TD]144g[/TD]
[/TR]
[TR]
[TH]Procesador[/TH]
[/TR]
[TR]
[TH]Color[/TH]
[/TR]
[TR]
[TH]Otros[/TH]
[/TR]
[/TABLE]
