GGFF
Vendo CASIO PRW 3000-1ER NUEVO A ESTRENAR.Lo entrego con caja,manual de instrucciones y garantía sellada el 22/03/2017 por tienda física.
El PVP OFICIAL ES DE 299€
NO ME INTERESA NINGÚN CAMBIO.GRACIAS.
Telf.687382121
[TR]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Marca:
[/TD]
[TD]CASIO[/TD]
[/TR]
[TR]
[TD]Modelo:[/TD]
[TD]PRW 3000-1ER[/TD]
[/TR]
[TR]
[TD]MARZO 2017[/TD]
[/TR]
[TR]
[TD]EL MISMO[/TD]
[/TR]
[TR]
[TD]NUEVO[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Movimiento:[/TD]
[TD]SOLAR[/TD]
[/TR]
[TR]
[TD]Caja (medidas):[/TD]
[TD]56mm x 47,03mm x 12,29mm[/TD]
[/TR]
[TR]
[TD]Cristal:[/TD]
[TD]MINERAL[/TD]
[/TR]
[TR]
[TD]Esfera:[/TD]
[TD]DIGITAL[/TD]
[/TR]
[TR]
[TD]Brazalete:[/TD]
[TD]URETANO[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]¿Estuche? s/n[/TD]
[TD]SÍ[/TD]
[/TR]
[TR]
[TD]GARANTÍA SELLADA Y MANUAL DE INSTRUCCIONES.[/TD]
[/TR]
[TR]
[TD]¿Garantía original SELLADA? s/n[/TD]
[TD]SÍ[/TD]
[/TR]
[TR]
[TD]SÍ[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Precio: (o cambio)[/TD]
[TD]200€[/TD]
[/TR]
[TR]
[TD]¿Envío incluido? s/n[/TD]
[TD]SÍ[/TD]
[/TR]
[TR]
[TD]Forma de envío[/TD]
[TD]CORREOS[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Especificaciones
Telf.687382121
[TR]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Marca:
[/TD]
[TD]CASIO[/TD]
[/TR]
[TR]
[TD]Modelo:[/TD]
[/TR]
[TR]
[TD]MARZO 2017[/TD]
[/TR]
[TR]
[TD]EL MISMO[/TD]
[/TR]
[TR]
[TD]NUEVO[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]SOLAR[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]Cristal:[/TD]
[TD]MINERAL[/TD]
[/TR]
[TR]
[TD]Esfera:[/TD]
[TD]DIGITAL[/TD]
[/TR]
[TR]
[TD]Brazalete:[/TD]
[TD]URETANO[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]SÍ[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]SÍ[/TD]
[/TR]
[TR]
[TD]SÍ[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]200€[/TD]
[/TR]
[TR]
[TD]SÍ[/TD]
[/TR]
[TR]
[TD]CORREOS[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Especificaciones
- Luz LED súper, completamente automática
En caso de luminosidad del entorno reducida, la pantalla del reloj se ilumina de forma brillante y a color al girar la muñeca. - Resistente al frío (-10 °C)
El reloj soporta temperaturas de hasta -10 °C. - Sistema de energía solar
El suministro de energía del reloj se lleva cabo mediante células solares independientes y respetuosas con el medio ambiente. La energía solar sobrante se almacena en una batería. - Recepción de señales de radiofrecuencia DCF/MSF/WWVB/JJY/BPC
Ya sea en Europa, Norteamérica, Japón o en Canadá, Centroamérica y China, una vez configurado el reloj según la zona horaria en la que se encuentre, éste recibe la señal de radiofrecuencia correspondiente para mostrar siempre la hora exacta. Además, en muchos países se activa automáticamente el horario de verano y de invierno. - Barómetro (260 / 1.100 hPa)
Un sensor especial mide la presión atmosférica (rango de medición: 260/1.100 hPa) y la muestra a través de un símbolo en la pantalla. Esto permite reconocer tendencias climatológicas de forma anticipada. - Termómetro (-10 °C / +60 °C)
El reloj cuenta con un sensor que mide la temperatura ambiente y la muestra en grados Celsius (-10 °C /+60 °C). - Brújula
El sensor de dirección incorporado detecta el norte magnético. - Altímetro 10.000 m
Un sensor de presión detecta cambios en la presión atmosférica y transforma estos datos en indicaciones de altura de hasta 10.000 m. - Suma de alturas
Con la suma de alturas, podrá sumar todos los metros que ha ascendido. Esta función le permite apreciar de un vistazo la diferencia total de altura que ha superado durante un recorrido. - Memoria del altímetro
En la memoria del reloj (depende del modelo) se pueden almacenar hasta 40 conjuntos de datos de altura para consultarlos en cualquier momento. Cada uno de los conjuntos de datos guardados consta de una medición de altura en combinación con una fecha y una hora. Además, junto con los datos de altura se guardan también las alturas máxima y mínima durante la medición. - Indicador de la salida y la puesta del sol
Después de introducir la posición geográfica, se pueden visualizar las horas de salida y de puesta del sol para cualquier fecha. - Función de hora universal
La función de hora mundial muestra la hora actual en hasta 29 zonas horarias distintas. - Cronómetro - 1/10 seg. - 1.000 horas
Medición precisa de tiempo transcurrido con el toque de un botón. La fracción indica la unidad de medición, mientras las cifras de tiempo indican las mediciones máximas de tiempo. - Temporizadores - 1/1 minuto - 24 horas
Para todos aquellos que exigen precisión: los temporizadores con cuenta atrás son de gran utilidad a la hora de recordar acontecimientos especiales o periódicos, ya que emiten una señal acústica a la hora programada. Se pueden configurar por minutos o hasta con 24 horas de antelación. Especialmente prácticos para la toma diaria de medicamentos o para el entrenamiento a intervalos. - 5 alarmas diarias
La alarma diaria le recordará las citas que se repiten a diario mediante una señal acústica que suena a la hora fijada. Este modelo está equipado con 5 alarmas independientes que le recuerdan sus citas importantes. - Función de despertador
Cada vez que para la alarma, suena de nuevo después de unos minutos. - Sonido de los botones activado/desactivado
Si se desea, es posible desactivar el sonido de los botones con el botón Mode. Una vez desactivado, el reloj dejará de emitir pitidos al cambiar de una función a otra. Las alarmas configuradas o el temporizador de cuenta atrás siguen estando activos después de desactivar el sonido de los botones. - Calendario automático
Una vez ajustado, el calendario automático muestra siempre la fecha correcta. - Indicación de hora normal de 12/24 horas
Las horas se visualizan ya sea en el formato de 12 o 24 horas. - Cristal mineral
El cristal mineral, duro y difícil de rayar, protege el reloj de daños exteriores. - Caja de resina
- Correa de resina
La correa contiene resina sintética, un material ideal para este componente dada su extrema resistencia y su flexibilidad. - Indicador de pila baja
Un indicador muestra el nivel de pila actual. - Clasificación de resistencia al agua (10 bar)
Perfecto para nadar y bucear: el reloj es resistente al agua hasta 10 bar / 100 metros. Esta indicación de metros no se refiere a la profundidad de inmersión, sino a la presión del aire que se ha utilizado en la prueba de resistencia al agua. (ISO 22810) - Dimensiones (A x A x P)
56mm x 47,03mm x 12,29mm - Peso
aprox. 62 g
