Sabéis qué precios se puede conseguir el MT-G en España?
Tengo dos localizados en amazon US (creo que son sin GPS, que tampoco me harían falta), ambos por 500 y pico dólares (luego con aduanas supongo que se quedan en los 550 euros.
Tampoco sé si hay alguna diferencia entre diferencia entre ambos:
Con fondo negro
[h=1]Casio MT-G Metal Twisted G-Shock MTGS1000D-1A[/h]
[h=5]Watch Information[/h][TABLE="class: a-keyvalue a-spacing-mini, width: 725"]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Brand, Seller, or Collection Name[/TH]
[TD="class: a-span7 a-size-base"]Casio[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Model number[/TH]
[TD="class: a-span7 a-size-base"]MTGS1000D-1A[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Part Number[/TH]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Item Shape[/TH]
[TD="class: a-span7 a-size-base"]Round[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Display Type[/TH]
[TD="class: a-span7 a-size-base"]Analog[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Metal stamp[/TH]
[TD="class: a-span7 a-size-base"]none[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Case diameter[/TH]
[TD="class: a-span7 a-size-base"]5.4 centimeters[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Case Thickness[/TH]
[TD="class: a-span7 a-size-base"]15.50[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Band Material[/TH]
[TD="class: a-span7 a-size-base"]Stainless Steel[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Band width[/TH]
[TD="class: a-span7 a-size-base"]20 millimeters[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Band Color[/TH]
[TD="class: a-span7 a-size-base"]Silver[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Dial color[/TH]
[TD="class: a-span7 a-size-base"]Black[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Special features[/TH]
[TD="class: a-span7 a-size-base"]Solar Power, 200 Meter Water Resistant, Atomic Timekeeping, Timer, Dual-Time, Shock, Centrifugal Force, and Vibration Resistant[/TD]
[/TR]
[TR]
Movement[/TH]
[TD="class: a-span7 a-size-base"]Quartz
[/TD]
[/TR]
[/TABLE]
y con fondo rojo
[h=1]CASIO MT-G G-Shock Model MTG-S1000D-1A4JF[/h]
[h=2]Product Specifications[/h]
[TR]
[/TR]
[TR]
[TD="class: a-span7 a-size-base"]MTG-S1000D-1A4JF[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Model Year[/TH]
[TD="class: a-span7 a-size-base"]2014[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Dial window material type[/TH]
[TD="class: a-span7 a-size-base"]Anti-reflection coating sapphire glass[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: a-span7 a-size-base"]15.5 millimeters[/TD]
[/TR]
[TR]
[TD="class: a-span7 a-size-base"]Solid Sainless Steel / Resin[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: a-span7 a-size-base"]Made in Japan[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Item weight[/TH]
[TD="class: a-span7 a-size-base"]6.56 Ounces[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Movement[/TH]
[TD="class: a-span7 a-size-base"]Solar[/TD]
[/TR]
[TR]
[TH="class: a-span5 a-size-base, bgcolor: #F3F3F3"]Water resistant depth[/TH]
[TD="class: a-span7 a-size-base"]200 Meters[/TD]
[/TR]
[/TABLE]
