![ffamora](https://cdna.relojes-especiales.com/data/avatars/m/1/1012.jpg?1621599232)
ffamora
Baneado a petición propia.
Después de mucho pensar, concluo: és hermoso !
¿ E vosotros ?
Saludos,
PS. Foto e Especificaciones técnicas:
Caliber : El Primero 4000 SX
Automatic Chronograph movement
13 1/4``` caliber. Diameter 30 mm. Height : 6.50 mm. 248 components
Chronograph bridge, balance & pallet cocks in shock-absorbing Zenithium Z+
Incabloc® anti-shock device
36’000 vibrations per hour
Power reserve over 50 hours
31 jewels
Measures short time intervals to a 10th of a second
Automatic winding in both directions
Central rotor on ball bearings
Heavy Metal oscillating weight with carbon fiber inserts
Functions : Hours and minutes in the center
Small seconds counter at 9 o’clock
Date at 4 ½ o’clock
Central seconds-hand for the chronograph
30-minute counter at 3 o’clock
12-hour counter at 6 o’clock
Case : Black Titanium case. Diameter: 46.5 mm
Black Titanium screw-in push-buttons with carbon fiber guilloché patterns
Black Titanium screw-in crown with specific protecting device
Graduated unidirectional rotating bezel in Black Titanium, with stainless steel decorative screw-heads & satin-finished titanium cone-shaped indexes
Helium valve at 10 o’clock
Black Titanium screw-in case back with carbon fiber guilloche pattern
Water-resistance up to 1’000 meters
Dial : Multi-layered shock-resistant structure composed of silvered & circular-grained subdial, Carbon fiber layer and silver-coated dial flange
Crystal : Sapphire glass, 3.8 mm thick, with anti-reflective coating on both sides. Magnifying lens over the date window at 4 ½ o’clock
Hands : All hands in rhodium with red Superluminova (luminous material) inserts.
Hour & minute “skeleton” rhodium hands
Bracelet : High-temperature resistant bracelet in brushed stainless steel.
Kevlar® lateral inserts and central links made of carbon fiber & composite alloys, with brushed stainless steel triple folded clasp.
![Vacile :cool1: :cool1:](https://cdna.relojes-especiales.com/data/assets/smilies/cool1.gif)
¿ E vosotros ?
Saludos,
![lostimage.jpg](https://cdna.relojes-especiales.com/res/img/lostimage.jpg)
31 jewels
Date at 4 ½ o’clock
