![2jewels](https://cdna.relojes-especiales.com/data/avatars/m/26/26418.jpg?1609024136)
2jewels
Me acabo de comprar este por 139€ mas IVA (153 €),
Caracteristicas:
(LA CAJA TIENE ACABADO PULIDO)
Case:
original Belstaff replica leather Burnt Brown
Water resistance:
up to 10 ATM
(Imagenes del bicho)
Uploaded with ImageShack.us
Teneis cronos VALJOUX por 300 euros
lo que pasa es que voy un poc pillao si no...
Caracteristicas:
Case:
- Diameter 40 mm
- The case is made of 3 pieces and moulded with “Double Frappe” system
- The lugs are screwed to the carrure and the bezel is made of stainless steel
- The screw down crown has a special thread for correct positioning of the phoenix
- The sapphire crystal case back is screw down too
- No reflection sapphire crystal
- Belstaff automatic movement based on ETA 2895-2
- 11 ½ lines
- 27 jewels
- 28,800 vibrations per hour
- Gilt nickel balance wheel
- Etachron regulator and stud
- Nivarox 2 spiral spring
- Super ll-A fine adjustment
- Second stop device during hour setting by drawn stem
- lncabloc anti-shock system
- 42 hour power reserve
- Belstaff personalized oscillating weight assembled on ball bearings
- Hour and minute central hands
- Date
- Small seconds at h 6
Water resistance:
up to 10 ATM
![Yho :yhoo:: :yhoo::](https://cdna.relojes-especiales.com/data/assets/smilies/yho.gif)
