![Efilio](https://cdna.relojes-especiales.com/data/avatars/m/0/483.jpg?1609024107)
Efilio
EN la web de IWc se pueden ver las fotos (hay que registrarse). Os dejo en enlace:
Platinum and Rose Gold Refine the Big Ingenieur
True greatness from within has been an intrinsic feature of the Big Ingenieur ever since its premiere. It was therefore an obvious step to accommodate its monumental seven-day automatic movement in a platinum case and in a rose gold case. After all, the refined appearance reflects the extremely attractive internal workings which, incidentally, are a trait shared by the entire Ingenieur family from IWC.
Ingenieur Automatic Edition “Climate Action”
For the Love of Our Planet
A carbon-neutral watch, made for a cause that benefits everyone – this is the Ingenieur Automatic Edition “Climate Action”. It is the symbol of a world that can be saved. Provided many people pull their weight. The campaign by environmentally aware management also helps. And IWC plays its part.
Ref. IW3234
Features
Mechanical movement, automatic Pellaton winding system, integral shock absorber system, date display, central seconds hand with stop function, limited to 1,000 watches
Movement
Calibre: 80111
Vibrations: 28 800/h / 4 Hz
Jewels: 28
Power reserve: 44 h
Winding: automatic
Case
Material: stainless steel and ceramic (zirconium oxide)
Glass: sapphire, antireflective
Back: ceramic mounting, stainless steel, engraved
Crown: screw-in
Water-resistant: 12 bar
Diameter: 44 mm
Height: 14 mm
Weight
Watch in stainless steel with black soft strap: 130 g
![lostlink.jpg](https://cdna.relojes-especiales.com/res/img/lostlink.jpg)
Ref. IW3234
Features
Movement
Calibre: 80111
Jewels: 28
Power reserve: 44 h
Winding: automatic
Case
Crown: screw-in
Diameter: 44 mm
Height: 14 mm
Weight
